Универсальный цифровой пробник на PIC контроллере 17 функций | |
m.ix 18/05/2010 04:05 |
Super Probe 17in 1 SuperProbe 17in one http://members.cox.net/berniekm/super.obj прошивка http://members.cox.net/berniekm/super.src сурс http://members.cox.net/berniekm/pic93.zip Логический пробник Частотомер счётчик импульсов диодный пробник измеритель ёмкости генератор генератор видеосигнала NTSC генератор сервосигналов и остально тут http://members.cox.net/berniekm/super.html 1 Prob - Logic Probe The logic probe shows 'H' for high (over 3.7 volts), 'L' for low (below 0.8 volts) and '-' for floating in the first display location. If a pulse is detected (0.5 usec minimum), the second location flashes a 'P'. 2 PULS - logic pulser The logic pulser shows the pulse rate (5, 50, 500, 5.0) in the last 3 locations. The first location shows the sensed logic level as a dash in the bottom or top of the digit. When button #1 is held down, a series of 0.5 microsecond pulses are generated in the opposite direction and the center segment is lit. Pushing button #2 cycles thru the 4 pulse rates. The selected pulse rate is saved on power down. 3 FrEq - Frequency Counter In the frequency counter mode, hitting button #1 switches the display to the next 4 digits of the count. For instance, the display shows '12.57' for a frequency of 12,576 hz. Holding down button #1 shows '2576' - the lowest 4 digits. If a decimal point shows, the value is in Khz, if the decimal is flashing, the value is in Mhz. Hence, a frequency of 42,345,678 hz is displayed as 42.34 with a flashing decimal. Holding down button #1 in this case will display 5678. 4 Cnt - Event Counter In the event count mode, the display shows the lowest 4 digits. Button #1 switches to the next higher 4 digits while held down. Button #2 resets the count. 5 VoLt - Voltmeter The voltmeter uses the power going into the probe as a voltage reference. The current implementation shows only an approximate voltage - about 2% high. This can still be very usefull for most measurements. Do not connect the probe to voltages that exceed 5 volts under any conditions. 6 diod - Diode Junction Voltage This is just the voltmeter function with 10k resitor feeding current to the probe tip. When a diode or transistor junction is connected from the tip to the ground lead, the drop voltage is displayed. 7 Cap - Capacitance Measurement When a capacitor is connected from the tip to the ground lead, and button #1 is pushed, its value is displayed. Values from .001 uf to about 500 uf are displayed. The larger the capacitor, the longer it takes to measure. A value of 100uf takes a couple of seconds. 8 Coil - Inductance Measurement When an inductorr is connected from the tip to the ground lead, and button #1 is pushed, its value is displayed. Values from 0.1 to 999.9 millihenries are displayed. Note: this function assumes that the DC resistance is not more than a few ohms. Also, if the unit gets 'stuck' in this mode, jumper the tip to ground to free it. 9 SIG - Signal Generator This mode generates a 500hz squarewave at about 0.5 volts. The signal is only generated while button #1 is held down. 10 ntSC - Video Patern Generates an NTSC video frame with a white dot pattern when button #1 is held down. 11 9600 - Serial Ascii Each time button 1 is pushed, the letters A-Z followed by cr/lf is generated. Auto polarity sensing. If the signal injection point is orignally high, then normal (zero start bit) ascii is generated. Otherwise, the other polarity is done. New feature: Button #2 cycles thru 1200, 2400, 4800, 9600 baud. 12 Midi - Midi Note Sends note number 60 (middle C) on any of the 16 midi channels. Holding button 1 sends 'note on'. Release of button 1 sends 'note off'. Buttton 2 cycles thru the 16 channels. The midi channel number is stored. 13 R/C Servo Generates 1ms to 2ms pulse for r/c servos. Button 1 increases pulse, Button 2 decreases pulse. Defaults to 1.5 ms each time mode is entered. 14 [ ] Sqaure Wave Generates 1 - 9999 hz squarewave. Button 1 decreases frequency, Button 2 increases frequency. 15 Prn - Pseudo Random Number Generates 10khz digital PRN series. 16 ir38 Generates 1 millisecond on and 2.5 millisecond off of 38khz square wave. When connected to IR LED, used for testing IR reciever modules. 17 PWM Generates variable pulse width 3-97 percent of a 6khz (approx) digital signal. Button 1 decreases pulse width, Button 2 increases pulse width. ================================================= http://320volt.com/pic16f870-ile-17-fonksiyonlu-test-ve-olcum-probu/ http://320volt.com/wp-content/uploads/2008/12/pic16f870-prob.rar прошика схема исходник |
m.ix 04/07/2010 00:04 |
m.ix 04/07/2010 02:47 |
m.ix 04/07/2010 03:59 |
http://benryves.com/journal/3632205 на pic16F876A
http://heli.xbot.es/SuperProbe/SuperProbe.htm http://heli.xbot.es/SuperProbe/SuperProbe3.png схема http://ikon.wz.cz/mondo/sonda_2.php http://ikon.wz.cz/mondo/files/super.obj прошивка переименовать в HEX ========================================= Prob Логический тест -------------------------- Этот режим очень полезен для обнаружения логических уровней или импульсы в цифровые схемы. На дисплее появится первая цифра 'H' на высоком уровне (около 3.7V), 'L' для низких (ниже питанием 0.8В) и "-" чтобы показать, что сигнал плавающей или высокий импеданс. Если импульсы выявлено более 0,5 микросекунд вторая цифра представляется 'P'. PULS Импульсный Генератор программного обеспечения --------------------------- Формирует импульсы 500ns шириной в один из четырех частот, доступных, полезных для потребителей инъекционных сигналов в цифровые схемы. На дисплее отображается частота импульсов (5, 50, 500, 5,0) в течение последних трех цифр. Первая цифра показывает логический уровень обнаружены с примесью вниз (низкий) в середине (высокий импеданс или плавающие) и выше (высокий). При нажатии BUT1 порожденных поезда импульса 0,5 мкс до обнаружены противоположные уровне логики. С BUT2 кнопку, вы можете изменить частоты пульса между 4 разными: 5Hz, 50Hz, 500 Гц и 5 кГц. Частота пульса выбрали сохраняется в EEPROM, чтобы они не пропустить после его остановки. VoLL Низкий масштаб вольтметр --------------------------- Простой вольтметр с разрешением около 5mV (хотя дисплей показывает только последние цифры кратны 10mV) со шкалой 0В до 5.00V, которая не должна быть превышена, поскольку это может привести к повреждению ПОС. Опорного напряжения самой власти (точность зависит от точности нормативной мощности). В новой версии программы 39 точное масштабирование происходит. До 1024 счетов раскол между двумя (один поворот вправо), для простоты, но он дал неточный результат: 5,12 В до 5,00 вход V Теперь масштабирование происходит в неподвижной точке V = (ANALOG1 * 500) / 1023 который обеспечивает точное значение. VoLH Вольтметр шкала высокой --------------------------- Этот новый способ версия 39 равна VOLL однако сокращение 0В до 25.00V. Имейте в виду, что эта резолюция является примерно 25mV (1 кол-во), так как конвертер имеет только 1024 счетов. Это нормально, что последняя цифра на дисплее скачок 2 в обоих блоках. Для измерения совпадает с входным напряжением должны быть связаны между делителя напряжения 5 включает в себя серию резистора 1М 1% и параллельных 249K 1%. diod Прозвонка диодов --------------------------- Показывает падение напряжения на стыке диоды, стабилитроны, или транзисторов. Это простое, 0-5V вольтметр, связанной с 10K резистор подключен к 5V, что делает небольшой источник питания. Измеренное значение имеет такой же точностью, как вольтметр, достаточной для выявления дефектных компонентов. После защиты стабилитрон Z1 параллельно с измерительной цепи максимальное значение, измеряемое в 4,5 V, напряжение, при котором начинает гнать стабилитроны D1. Freq Частотометр --------------------------- Частота до 40MHz, время измерения 1 секунду. На дисплее появится цифра 4 тяжесть частота этого при входе. Нажатие BUT1 включен, чтобы показать как минимум 4 значащих цифр. Например, если на дисплее отображается '12 57 'на частоте 12,576 Гц. BUT1 нажав показывает, '2576 '- 4 цифры ниже. Исправлена десятичной точки указывает Khz, если мигает указывает МГц. Частота 42345678 Гц, как показано 42,34 с запятой мигать. Нажатие отображает BUT1 5678. Cnt Счетчик событий --------------------------- Это простой счетчик импульсов. На дисплее отображается 4 наименее значащих цифр, при нажатии BUT1 4 цифры показали больший вес. BUT2 кнопки сбрасывает внимание к нулю. Cap Измерение ёмкости --------------------------- Нажатие BUT1 мера емкости конденсатора соединены между зондом и массы. Диапазон измерения 001 до примерно 500 мкФ мкФ. Время измерения пропорциональна конденсатора для измерения 100 мкФ нужно несколько секунд. Coil Измерение индуктивности --------------------------- Нажатие BUT1 меры индуктивность катушки соединены между зондом и массы. Диапазон измерения от 0,1 до 999,9 mH. Предполагается, что сопротивление катушки не более чем несколько Ом. Замыкание отзыв измерения массы калибровочных блока бесплатно. SIG Генератор сигналов --------------------------- Генератор прямоугольных 500 Гц и 0,5 вольт, удерживая BUT1, очень полезно для тестирования аудио-и аналоговых схем. ntSC Генератор NTSC видео --------------------------- Формирует изображение, сформированное структуры белые точки на черном фоне в видео формате NTSC для тестирования цепей с помощью этого формата изображения. В Испании мы используем стандарт PAL, я пытался его приемник Multistandard и работает хорошо, но мало пользы. 9600 9-битный (8N1) ASCII --------------------------- Используется для проверки цифровых схем с использованием правильно получить серийный ввода данных. Каждый раз, когда вы нажимаете участок образуется BUT1 серии буквы А после возврата каретки и перевода строки (CR / LF есть). Сигнал полярности сторнируется таким образом, если измерять уровень высок сигнал генерируется нормальный (ноль стартовый бит). Если обратной полярности используется. BUT2 кнопку, чтобы изменить скорость: 1200, 2400, 4800, 9600, 19200, 34800, 57600 и 115200 бод. Midi MIDI генератор --------------------------- Для проверки включения Музыкальные инструменты MIDI интерфейс. Отправить отметить, номер 60 (C в среднем) на любой из 16 каналов MIDI. Нажатие BUT1 послал заметка в ', чтобы освободить ее посылает' сведению выкл ". BUT2 кнопку, чтобы выбрать один из 16 каналов. Канал сохраняется от сбоев питания. R/C.o сервотестер --------------------------- Позволяет проверить сервоприводы управления по радио. Генерирует импульсы 1 мс 2 мс возможность установить полный оборот сервомашинки. Дисплей показывает длительность импульса микросекунды. BUT1 кнопку уменьшается ширина импульса и BUT2 кнопку увеличивает его. По умолчанию это 1500 миллисекунд (1,5 мс в центре) каждый раз, когда вы выберите этот режим. Импульсы каждые 35 мс или около того (частота 28Hz). R/C.i сервотестер --------------------------- Используется для тестового сигнала генераторов для управления по радио сервоприводы, RC ресивера или счетчик импульсов общий характер. На дисплее отображается микросекунд или миллисекунд входного сигнала остается на уровне (высокий или низкий, отобранные). Например, в 1500 составляет 1,5 мс (чтобы добраться до центра позиции для серво RC), если десятичная точка на дисплее данные показали представляют миллисекунд. При нажатии отображается BUT1 H и освобождения и непрерывно измеряет время, сигнал высокого уровня. Нажатие BUT2 показывает, L и выпуск непрерывно измеряет время сигнал низкого уровня. При отсутствии входного сигнала остается конечной мерой. При измерении можно увидеть небольшое мерцание на дисплее. В этом режиме проверяется 700US сигналов 100 мс, но может быть измерена с 10us более 16 секунд. [ ] Генератор меандра --------------------------- Генератор прямоугольных импульсов (50% рабочий цикл) от 1 до 9999 Гц BUT1 кнопку уменьшается частота и BUT2 кнопку увеличивает его. Это полезно для калибровки метров частоты сигналов в цифровые схемы придать т.д. noiS Генератор псевдослучайных сигналов --------------------------- Цифровой шум (псевдо) на 10 кГц. ir38 LED IR --------------------------- Генератор прямоугольных импульсов 1 мс и 2,5 мс с на 38kHz. При подключении инфракрасного излучателя светодиодный может быть использован для тестирования модулей ИК-приемник. PWM Широтно-импульсной модуляции --------------------------- Создает переменной ширины импульса от 3% до 97% примерно до 6kHz. Нажмите BUT1 импульса уменьшается, а увеличивает его BUT2 кнопку. Очень удобно использовать для тестирования усилителей для двигателей постоянного тока или PAP. ========================================= http://4shared.com/download/NPYIgP5p/SuperProbe.rar |
m.ix 04/07/2010 05:46 |
m.ix 04/07/2010 09:01 |
Во время режима работы NTSC на экране монитора-телевизора выводятся белые точки - для центровки растра удобно.
m.ix 04/07/2010 17:35 |
измерил лит 4700
показал 5027 сравнил с иным дорогим прибором тоже 5 с чем то показал. литы долго измеряет 4700 где то минуту полторы 10000 мкф минут эдак 5-10 ДОБАВЛЕНО 04/07/2010 19:01 Проверка диодов Можно прозванивать диоды проверять стабилитроны до 4.7-5.1 v Ну и светодиоды. |
m.ix 04/07/2010 18:36 |
минимальный на миллигенри предел
ДОБАВЛЕНО 04/07/2010 20:17 СОбственный генератор может выдавать прямоугольные 5в импульсы от 1Гц до 32кГц |
GruVital 04/07/2010 20:18 |
m.ix, Михаил, заинтересовал такой примочкой, обязательно соберу, будет время! |
m.ix 04/07/2010 20:31 |
Если ещё у кого то есть авиамодели и серводвижки, то там тоже имеются сигналы для управления серводвижками.
Пока эту опцию не проверял. В Режиме PROBe можно анализировать выходы логические - L H -P LP |
yucan 07/07/2010 07:42 |
Очень интересный прибор.Удивляюсь откуда у M.ixa столько времени на творчество?
генератором сервосигналов я так понял можно проверять сом порты |
m.ix 07/07/2010 11:00 |
Наверное и можно проверять, правда ума не приложу как это и каким место проверять. |
yucan 08/07/2010 09:03 |
Немного разобрался по генераторам этого пробника
В версии прошивки 41 19 функций Генератором сервосигналов не знаю что можно проверять А еще есть 9-битный последовательный выход 8+1 в формате ASCII это для проверки сом портов. Формирует букву А + вк+пс скорость можно менять19,38,57 и 115 Кb Генератор меандра от 1 до 9999 Гц Генератор 38 кгц для проверки ик приемников Генератор 500 гц 0,5 в Генератор шума |
m.ix 10/07/2010 14:44 |
Когда измерял ёмкость 10000мкф то на индикаторе высветилось 1156 к примеру и первая точка медленно при этом мигала где то в полГц |
m.ix 22/08/2010 04:16 |
попробовал измерить 18000мкф
измерил но времени на это ушло где то минут пять 1000мкф 30секунд 100мкф 3-4скунды |
yucan 28/08/2010 10:02 |
Собрал но ни фига не разберусь.
вроде работает но где какая функция? При включении 3 черты - так должно быть? |
m.ix 28/08/2010 13:40 |
при включении высвечивается на секунду
Prob а после лишь одна черта. переключение функций идёт двумя кнопками одна при этом постоянно нажата останавливаясь на нужной опускаем обе. |
Zeba 19/09/2010 19:25 |
А хекс имеется к первому вареанту на pic16f870 ? Странный файл прошивки там |
m.ix 19/09/2010 20:44 |
Zeba, я им прошил
что ты и видишь на скринах. |
Zeba 19/09/2010 22:39 |
m.ix, попробую собрать, клёвая штука А в каких приделах можно ёмкость мерять? В описании 500 мкФ, а например 10000 мкФ и большая погрешность будет? |
m.ix 19/09/2010 22:54 |
10000 он сможет измерить но думаю у тебя устанет рука держать эту ёмкость.
если у тебя есть макетка попробуй на проводочках собрать на 628 где транзисторы в управлении индикаторами есть. у того что я собрал, что то с яркостью не то. малова то её. |
Zeba 22/09/2010 21:28 |
m.ix, а там пишут, что индикация хитрая- в еденицу времени отображает только один сигмент, я приабрёл индикатор из сереии Super Red посмотрю, что получится. У меня вопрос возник по защите МК от случайного напряжения выше 5в на входе, можно к первому варианту на pic16f870 применить супресор на 5.6в и предохранитель? И отразится ли на работе зонда его включение по входу? |
m.ix 23/09/2010 01:02 |
только предохранитель ставить
можно ещё и делитель как вариант ранее приведённый |
m.ix 05/10/2010 09:40 |
http://www.youtube.com/watch?v=D5X8gSjFmJQ
Вот как у некоторых это получилось, точнее хорошо осциллографически это видно. |
yucan 06/10/2010 11:07 |
Я собрал на Pic16f876. В оригинальной прошивке 10 функций.
Хотелось бы иметь все 17,никто не видел такую версию? Как сделать корпус пробника,чтобы как у автора? |
m.ix 06/10/2010 17:05 |
==================== Какую версию делал? (как там с яркостью?) Как сделать корпус пробника,чтобы как у автора? ==================== Купить сломаный мультиметр. |
yucan 06/10/2010 18:17 |
Да с яркостью не очень.при хорошем освешении плоховато
видно. Прошивку брал с сайта benryves_com.А вид хотелось бы вто такой |
m.ix 06/10/2010 18:23 |
Если читал текст, то она демка и автор исходил из своих соображений. - Гугль переводчик.
Корпус можешь любой из квадратных прямоугольных выбрать. |
yucan 06/10/2010 18:30 |
Понятно, может и демка,но заявленные 10 функций работают.
А насчет корпуса есть мысль сделать из эпоксидки,типа папье-маше как раз под размеры пробника с кроной. благо ток небольшой жрет. |
m.ix 10/10/2010 07:08 |
ljолнительная микросхема и транзистор на выходе повышают яркость дисплея. |
yucan 12/10/2010 17:36 |
Спасибо.В собранной мной схеме используется только транзистор
на выходе PICa. Переделывать уже не буду, может в слудующий раз - буду иметь ввиду. |
m.ix 12/10/2010 18:54 |
yucan, там где нет ни чего
навешивание транзисторов приводит к инверсии, для этого и стоит инвертор. |
yucan 13/10/2010 16:56 |
Да я понял. В схеме на 870 PICe ничго не стоит.
В схеме на 876 PICe стоят транзисторы,но там ведь тоже можно поставить инверторы, но применить индикаторы с общ.катодом. |
m.ix 13/10/2010 18:52 |
Я не про АО ОК
А про повышение яркости. |
Zeba 25/10/2010 21:58 |
Собрал первый вариант, на PIC16F870 яркости достаточно, а вот в режиме генератора [] сильно мерцает табло и поставил стабилитрон на 5.6v 1.3w для защиты входа, теперь зонд в режиме CAP (измерения ёмкости) показывает 200 пФ А так впринцепе я очень доволен все 17 функций присуствует! Небольшые трудности были с управлением, но быстро разобрался, кнопку But 2 надо зажать, а But 1 переключаются функции. Светодиодную матрицу использовал RL-F5620SBRW(оа) из серии Super Red. |
yucan 27/10/2010 17:34 |
Я стабилитрон на входе убрал т.к. вносит погрешности в
измерениях.В режиме генератора должен показывать частоту. Щас леплю корпус прибора из эпоксидки и марли 130*30*25 с источником питания (крона). |
m.ix 27/10/2010 20:36 |
На митьке продают длинный узкий корпус. |
Zeba 27/10/2010 20:48 |
yucan, да он показывает частоту, но табло мигает с частотой 20 Гц примерно только в режиме генератора []. И при включении показывает гдето одну секунду 036, а потом Prob, странно что оно означает? |
yucan 28/10/2010 17:34 |
У меня пробник собран на PIC16F876 и при включении сразу загорается черта в левом
разряде,потом кнопками - PrOb, PULS и т.д. В режиме генератора мерцаний не замечено. В целом - все хорошо,но недоволен точностью измерения емкости - почти полностью высохшие показывает как потерявшие емкость. m.ix за информацию спасибо. |
yucan 05/12/2010 11:14 |
Додоелал корпус - это самый первый,сделанный из материи,пропитанной
эпоксидкой.Потом вместо материи использовал бинт,стеклоткань,но все неудачно.Проблема в формовке при застывании и снятии с заготовки. Вот что получилось ДОБАВЛЕНО 05/12/2010 12:27 Чото не прикрепляются... В данный момент доволен. Быстро можно пробежаться по схеме, сделать какие то измерения. |
m.ix 16/01/2011 09:56 |
Вчера шикарненькие цифирьки FYQ-3641BS-21 приобрёл
И главное что яркие но к сожалению не особо маленькие. |
gogaon 22/02/2011 04:28 |
Всем доброго время суток прочитав данную статью очень загорелся таким прибором . Проверив все и отыскав детали стал придумывать в какой же корпус это все запихать . Неожиданно для себя обнаружил корпус весь в пыли и грязненький от старого мультиметра из самых первых китайских цифровых М830 (также подойдет М832 и тд ) решился сделать в нем вынул родную плату произвел замеры в лаете нарисовал и вуаля получилось вполне не плохо .Делюсь своей печаткой . Примечание : кнопочка на питание с фиксацией от старых магнитол . верхние края немного закруглить индикатор 18мм ширины . на заднюю крышку приклеил фольгу и подключил к минусу так меньше наводок . вроде все а это все под 41 прошивку транзисторы А1123 с ними ярче светиться . |
m.ix 12/03/2011 04:39 |
Сегодня был в кварце и увидел в продаже сей дэвайс за 50$
fanzone 13/04/2011 02:00 |
народ поделитесь плиз печатками под 870 камень без транзисторов
спасибо заранее. |
m.ix 17/04/2011 00:22 |
Решил сопли в корпус подобрать.
ДОБАВЛЕНО 17/04/2011 02:14 |
m.ix 17/04/2011 01:41 |
ДОБАВЛЕНО 17/04/2011 03:17 |
m.ix 17/04/2011 08:21 |
m.ix 08/05/2011 09:54 |
Где то 10-20 минут прошло, что б высветились показания измерений ёмкости.
Точка мигает 1 раз в 5 секунд Время измерения 3-4 минуты Точка горит постоянно Ёмкость конечно не фонтан. Время измерения 5-7 секуунд Точка горит постоянно |
voffka 08/05/2011 10:25 |
m.ix, печатку дай. |
m.ix 08/05/2011 10:59 |
Плату можно как шаблон применить, она пару постами выше.
Как по линейке Далее результаты измерений ёмкостей не гарантированы. |
m.ix 16/05/2011 00:04 |
========================================== Это по видимому версия прошивки 036 - версия прошивки FREQ - режим измерения частоты (включается в том режиме в которым в последний раз измерял до отключения) 0000 - частота в Гц (см инструкция 1 страница) |
alexadresat 20/05/2011 16:26 |
Собрал схемку на 16F876A прошил 41-ю версию.
Работает, но в режиме частотаметра в показаниях сильно приверает.... Может кто-то сталкивался с такой проблемой. Подскажите, как выйти из этого положения??? |
INSAN 21/05/2011 00:46 |
аТЫ СДЕЛАЙ УСЁКА мИХА ДЕЛАЕТ.. И будет те фсё ныштяк ДОБАВЛЕНО 21/05/2011 01:52 18/05/2010 - 16/05/2011 , двух дней не хватило до года |
cherr 24/05/2011 23:29 |
Есть ли возможность собрать прибор на 16F873A? Помогите переделать прошивку. |
m.ix 25/05/2011 04:30 |
cherr, тебе дешевше выйдет купить МК |
amid- 25/10/2011 20:14 |
Помгите не скачивается прошивкадля pic16f876a
дайте ссылку |
atmicandr 26/10/2011 07:32 |
Миша, прекрасная штуковина! Сам такое захотел... |
m.ix 26/10/2011 10:01 |
хочу ещё одну подобную штуковину попробовать собрать
на сколько она заработает хез, если вообще заработает, тк нет в продаже нужного. http://radiokot.ru/forum/viewtopic.php?f=2&t=57091 |
penzet 09/11/2011 14:25 |
m.ix,В архиве только файлы для Eagle, дайте пожалуйста прошивку для PIC16F872
ДОБАВЛЕНО 09/11/2011 15:28 m.ix,В архиве только файлы для Eagle, дайте пожалуйста прошивку для PIC16F872 |
m.ix 09/11/2011 21:48 |
всё что было найдено то и выложено. |
penzet 10/11/2011 14:37 |
Странно. Зачем же вы собрали прибор на который у вас нет прошивки? |
m.ix 10/11/2011 21:10 |
я тему собрал как и один точнее уже три в железе прибора
Но на ином МК |
penzet 11/11/2011 10:48 |
Понятно
А можно посмотреть на схему вашего прибора, мне то все равно на каком мк собирать главное чтобы работал |
m.ix 11/11/2011 10:50 |
А что её нет на первой странице первого поста? |
penzet 11/11/2011 13:16 |
Ладно проехали. Как у Райкина тут про колеса а тут про насосы. |
slyfox 30/11/2011 00:59 |
Ввообще то прошивка от 16f870 где все 17 функций - прекрастно работает и на 16f873 и на 16f876 без переделок, только на 876 не сохраняется в памяти то что последнее вы измеряли, т .е. все сначала с первого пункта. 876 отличается увеличенным обемом памяти и прошивка от 870 не корректно туда записывает или не записывает совсем. С 873 таких проблемм нет все прекрастно работает. Собирал где- то года 2 назад. |
monser 30/11/2011 12:13 |
Интересная конструкция. Решил собрать, заказал микросхемы в корпусе SO28.
Только потом сообразил, что в моем прогере BiDiPro нет переходника для этого корпуса. В даташите указано, что в ней имеется последовательный интерфейс. ATMegi прошивал понипрогом с STK200/300 , но похоже что к PICам он не подойдет. Подскажите плиз кто чем их программирует через USART. |
atmicandr 30/11/2011 12:31 |
monser, программируй понипрогом через адаптер SIProg для пиков. Параллельный порт есть? Если да, то сделай адаптер AN-589 он простейший!!! И тогда шей через WinPic800 |
monser 30/11/2011 14:01 |
А какой адаптер следует выбирать в WinPic800 ? |
atmicandr 30/11/2011 14:50 |
jdm и AN589 соответственно |
monser 01/12/2011 01:41 |
А JDM то работает только с COM а не LPT
asel 06/01/2012 19:48 |
Вот V.43
http://www.talkingelectronics.com/te_interactive_index.html Добавьте кто может, чтобы еще резисторы измерял |
valexus 18/04/2012 22:11 |
Вот интересная модернизация данного прибора, уже 20 функций.
http://heli.xbot.es/wp/?p=40 В pic16f873a и pic16f876a лезет на ура (всего 3к кода), и сохраняется в eeprom после выключения -- сам проверял. Только нужно ставить еще один инвертор перед транзисторами (74HC00N), для собранных прошивок, либо не ставить транзисторов вообще. Прошивки для общего анода. Будьте внимательны, читайте с переводчиком. |
asel 29/09/2014 19:58 |
"Мутный" какой-то у Heli "пробник". Я собрал на pic16f876a. Напряжение неправильно измеряет. Омы меряет, но не пищит. На IrGen вообще какая-то муть. Может в проге у него ошибки? 150 ом я не впаивал. ..Перепаял входы и перепрошил по http://www.talkingelectronics.com/projects/SuperProbeMkII/SuperProbeMkII.html ... Все работает, как описано. Только нету "Таймера"?! |
vintick 26/10/2015 01:24 |
почему то не могу открыть ни одной ссылки |
bdw55 14/02/2018 21:53 |
подскажите спецы, а стабилитрон 5.1 на щупах решит проблему переполюсовки ??? |
