Куплю матрицу к телевизору Toshiba 42A3000PR по Украине | |
| dunga 10/04/2015 09:17 |
http://www.buyqual.com/lc420wx7-sla1-lg-display-42-inch-a-si-tft-lcd-panel.html LG.Philips LCD Panel Model : LC420WX7-SLA1 Panel Type : a-Si TFT-LCD, Panel Panel Size : inch Resolution : , Display Mode : Super IPS, , Surface : , Brightness : cd/m2 (Typ.) Contrast Ratio : Display Colors : 16.7M (8-bit) Response Rime : 10 (Typ.)(Tr+Td); 5 (Typ.)(G to G) Viewing Angle : 89/89/89/89 (Min.)(CR≥10) (L/R/U/D) Frequency : [BuyQual copyright, copy is strictly prohibited] 60/120Hz : 60/120Hz Switchable 120Hz (60HZ Input) : Embedded MEMC Circuit 120Hz+120Hz : 120Hz Panel+120Hz Backlight 240Hz (60HZ Input) : Embedded MEMC Circuit Lamp Type : 8S6P: 8 Serial, 6 Parallel Signal Interface : LVDS (1 ch, 8-bit) Input Voltage : 12.0V (Typ.) |
| Шепітко Руслан В. 10/04/2015 09:40 |
US $305 через два тыжни буде у вас в руках нова.. мы поставляэм з кытаю . |
