Драйвер для вебкамерыCreative PC-CAM 880 | |||||
| разЯРЕННЫЙ 21/08/2007 09:05 |
Розыскивается драйвера для вебкамеры Creative PC-CAM 880.К сожилению все ссылки на эти драйвера битые.На сайте производителя отсутствуют.Господа поделитесь вдруг у кого есть немогу найти. |
| Uznik 21/08/2007 22:05 |
А ты,
разделом не ошибся? http://monitor.espec.ws/section13/ |
| m.ix 21/08/2007 22:48 |
http://ru.europe.creative.com/support/downloads/download.asp?MainCategory=218&nRegionFK=&nCountryFK=&nLanguageFK=&sOSName=Windows+XP®ion=3&Product_Name=PC-CAM+880&Product_ID=308&modelnumber=&driverlang=1049&OS=10&drivertype=1&x=32&y=14
http://ru.europe.creative.com/support/downloads/download2.asp?MainCategory=218&Product=308&dlcentric=2193&Product_Name=PC%2DCAM+880&filetype=1&OSName=Windows+XP Вот что отписал родной производитель Creative PC-CAM 880 Readme File May 2003 ------------------------------------------------------------------- This document contains late-breaking or other information that supplements the Creative PC-CAM 880 documentation. Please read this document before you proceed with the installation. PCCAM 880 Installation instructions: If you are experiencing problems with installation or camera is not detected by PCCAM Center, please follow this setup procedure. 1) Install Driver and application 2) Connect PcCam880 Camera to your computer 3) After connecting your camera. Windows automatically detects the device. Do not proceed to the next step until camera is fully detected by windows 4) Windows will install drivers for USB Mass Storage Device and camera's LED indicator should light up in red 5) Press Mode button on the camera, Your camera's LED indicator lights up in green This will install drivers for webcam part of the camera and will allow you use the camera in PCCAM Center. IMPORTANT: Unless this step is followed, PCCam Center will not detect the camera and report that - no creative device is present on the system. When camera is connected to PC and LED lights up: RED- Mass Storage Mode (Default) Function as an Additional Drive of the PC. Image files can be found under the route Removable Disk\DCIM\ Under this mode, you can read,delete,move, or copy the image files you want. and could be switched to: GREEN- Camera works as webcam only . Picture download/browsing is not possible when camera switched in Webcam mode. Switching between Live Mode and Digital modes in PCCAM Center requires that camera mode button is switched accordingly. ================= Брал тоже в качестве ( думал в основном фотки таскать , а оказалось он еще и mp3 весьма недурственно воспроизводит ) фотоальбома X5L 20GB . У меня Creative PC-CAM 880 и Genius G-Shot DV-610 подключаю все в выключенном состоянии . Включаю X5 / перехожу в USB-Host ,фотоаппарат зажигает красный светодиод / нажимаю и держу кнопку Rec на X5 , до появления надписи DEV на дисплее X5-го / выбираю из каталогов фотоаппарата нужное и копирую . Очищаю карточки только средствами самих фотоаппаратов ( Format Card ) На мой взгляд ежели устройство не требует драйверов при подключении к компутеру , то и X5 его поймет и будет работать . Но есть вероятность некорректной работы в случае большого потребляемого тока при работе "в паре" , либо помех со стороны фотоаппарата . Я бы попробовал в разных режимах подключаться . USB кабель может быть плохим ( мне с одним из фотиков шел в комклекте USB-2 кабель с непостоянным контактом в разьеме - выбросил нах ибо есть второй ) ================= Походу эта камера опознаётся лишь как дисковый накопитель Это её характеристики http://www.nix.ru/autocatalog/videoconference/Creative_CAM_880_3.0Mpx_19439.html А для работы в вэб режиме нужен софт из комплекта WebCam Monitor Подключи её, может в автоматическом режиме дрова с сайта установятся. http://driver.ru/?V=Creative-Labs&S=41 только до 750 и софт к ним http://www.helpdrivers.com/ingles/listado/panel.asp?marca=Creative&perif=camaras тоже до 750 |
| m.ix 21/08/2007 23:58 |
разЯРЕННЫЙ,
Если скачаешь выложи сюда в обенник. Если в аглицком разбираешься http://www.camera-drivers.com/drivers/128/128585.htm http://members.driverguide.com/driver/detail.php?driverid=128585 http://forums.windrivers.com/archive/index.php/t-56177.html http://list.driverguide.com/list/company258/page10/index.html |
| разЯРЕННЫЙ 22/08/2007 06:33 |
Спасибо уважаемый сейчас буду разбираться.Как вы уже заметили есть проблема с этими дровами.Мне бы хотелось найти под нее софт но вот незадаче нету.При чтении с флеши проблем нету, хотелось бы и камеру сделать из нее вот и ищу дрова.Если солью непременно скину. |
| m.ix 22/08/2007 11:13 |
Так что именно? Софт я уже выложил. см ссылки. |
| разЯРЕННЫЙ 29/11/2007 20:07 |
Я конечно явно запоздал но, лучше поздно чем никогда.Ввиду непонятных заморочек еле выкачал.Установил а толку нет.Выяснил буквально наднях.Комп стоит на работе под столом и естественно туда кроме технички никто незаглядывает.Вобщем брал у меня кто -то в мое отсутствие мышь USB и воткнул ее в обратно в USB.Вот только это кто-то напутал потому как у меня она была в PS\2 через адаптер.А вот в адаптер воткнули шнур от камеры.Делаю вывод: или кто-то прокасячился или кто то нехочет чтоб я знал кто ходит мимо моего стола в мое отсутствие.Вобщем заработала она, теперь пишем вовсю.
m.ix , Спасибо за помощь. Вот только куда выложить туплю.Общий вес 3.6 мегов.
ДОБАВЛЕНО 29 Ноябрь 2007, 23:09
| m.ix 30/11/2007 14:32 |
http://archive.espec.ws/ |
