Erisson 2910A шасси 5N11 | |
| Yuritsh 31/03/2010 22:21 |
Erisson 2910A шасси 5N11 / Erisson 2102, 21F1, 2520, 2910, 2915, 2920, 25TI60, 2910А, 29SI60, 29TB65, 29TJ70, 34TJ70, 34TP75
Клоны: Akai 2522, 2588, 25F1, 2922, 2929, 2998, 29F1, 3423, 3498, CT-2867, D25, D29, D34, L25, L29, L34 / Akira CT-25DS9AE, CT-25DS9AN, CT-25FS9A, CT-25FS9AN, CT-25LS9AE, CT-25LS9AN, CT-25NI9A, CT-25NI9AE, CT-25NI9AN, CT-25NI9AT, CT-25NI9ATS, CT-25NX9A(SKD), CT-25NX9A, CT-25NX9AE, CT-25NX9AN, CT-25XG9A, CT-25XG9AN, CT-29DS9AE, CT-29DS9AN, CT-29DS9AW, CT-29FS9, CT-29FS9A, CT-29FS9ATS, CT-29FS9C, CT-29FS9MK1AN, CT-29FS9MK1AT, CT-29FS9MTS, CT-29LS9A, CT-29LS9AE, CT-29LS9AN, CT-29LS9AS, CT-29LS9AT, CT-29LS9ATS, CT-29LS9MTS, CT-29NI9A, CT-29NI9AE, CT-29NI9AN, CT-29NI9AT, CT-29NI9AU, CT-29NX9AE, CT-29NX9AN, CT-29PF9A, CT-29PF9AE, CT-29PJ9AU, CT-29PS9AE, CT-29SG9AU, CT-29SJ9AU, CT-29SK9AE, CT-29ST9AU, CT-29TJ9AE, CT-29TJ9AN, CT-29TJ9ATS, CT-29TK9AE, CT-29TK9AN, CT-29TK9AU, CT-29TW9AN, CT-29XG9, CT-29XG9A, CT-29XG9AE, CT-29XG9ATS, CT-29XG9MK1AE, CT-29XG9MK1AN, CT-29XG9MK1AT, CT-29XG9MK1ATS, CT-29XG9MK1N, CT-34DS9, CT-34DS9A, CT-34LS9, CT-34LS9A, CT-34LS9AN, CT-34PF9, CT-34PF9A, CT-34PF9AE(SKD), CT-34PF9AN, CT-34PF9C, CT-34PTP9A, CT-34SG9, CT-34SG9AN, CT-34TP9, CT-34TP9A, CT-34TP9AS, CT-34TP9ATS / Amstrad SF38US / Distar DT-29Y1 / Elenberg 29D77 / ERC 25TI60, 2915, 29SI60, 29TB65, 29TJ70, 34TJ70, 34TP75 / Hyundai HU-D25A, HU-D29 / Oniks 97ТЦ15-99 / Platinium 63NX-Plat / Premier PR-74020T, PR-7540T, PR-7750T / Quadro CTV63S10, CTV6325TXT, CTV72C10, CTV72I10, CTV72V10 / Quart QTV7222 / Saturn ST-25NF1D, ST-2939A, ST-3423 / Skyworth / Supra ST29K22B, ST29K33F, ST34K22B / Tensai 2522, 2588, 25F1, 2922, 2929, 2998, 29F1, 3423, 3498, 3898, D25, D29, D34, L25, L29, L34 / West 29G19 ..................
СХЕМА шасси 5N11 (1.2 MB) ПРОШИВКА на шасси 5N11 ВХОД В СЕРВИСНОЕ МЕНЮ СОСТАВ ШАССИ: Main - 5800-A5N110-02 Size - 330x295mm Micom - S3C8849X30-AQB9 SKY-5N11-01 Memory - ST24C04W 6 SMPS - STR-F6656 TR Chopper - 5115-064201-31 SAW - K6959K & Q9350M Video - NN5198K Vertical - даташит на TA8427K Teletext - STV5348 Vertical correction - TA8859CP Sound - даташит на TA8256BH Stereo - MSP3410D Tuner - ENV59D68F1E TV/AV - HEF4052P Tube - A68ESF004X111/NV00 FBT - JF0101-0166 5100-051029-00 (HR7424) HOT - даташит на 2SC5148 RGB Amp. - BF420 & BF421 Пульт: - FHS083 IC remote - даташит на PT2210 Other ICs - AN5891K ТЕМЫ С НЕИСПРАВНОСТЯМИ: Не работает коррекция Проблемы с настройкой Не останавливается настройка Мал размер по горизонтали (подушка) БП STR-F6656 Блок питания Периодически пропадает растр |
