Sony KV-HR29M91 шасси AX-1 | |
| B.B. 22/05/2010 16:07 |
Sony KV-HR29M91 шасси AX-1 / Sony KE-MX37A1, KE-MX37S1, KE-MX37N1, KE-MX42A1, KP-FR43M31, KP-FR43M90, KP-FR43M91, KP-FW46M91, KP-FW51M90, KP-FWS57M90 (SCC-M14K-A), KV-HR32K90, KV-HR32M31, KV-HR32M90, KV-HR36M31, KV-HZ29M55, KV-HZ29M80
СХЕМА шасси AX-1 (3 MB) СХЕМА шасси AX-1 (7.1 MB) СХЕМА шасси AX-1 (12.51 MB) СОСТАВ ШАССИ: Master Micro - CXP961048-013Q PF Micro - M306VSMG-555FP Memory - 24C32-WMV6T FLASH ROM - MBM29LV160BE-90TN-AX005 SDRAM - MY57V281620HCT-H-TR Reset - MM1482BFBE SMPS - MCZ3001DB 135v CONT - BA9759F-E2 Vertical - даташит на STV9379 Component I/F - CXA2170Q Memori Stick Interface - MB93491 Audio Processor - даташит на NJW1148 Sound - TDA7296, TDA7490L Tuner - BTF-WG442 Tuner PIP - BTF-LG434 D/A Converter - SAA5360HL/0004 Main Combfilter - SXA2163AQ Input Select - CXA2188Q, CXA2189AQ CCP2 - CXD3802BQ SDRAM - MT48LC2M32B2TG, MSM56V16160F-8T DRC-M - CXD2097BQ MID-X - CXD9509AQ FBT - NX-6020/M3B4 HOT - 2SC5778-RB S-COR-OUT - 2SK3262 RGB Amp. - даташит на TDA6120Q Пульт: - RM-1008 / RM-1007 ТЕМЫ С НЕИСПРАВНОСТЯМИ: http://monitor.espec.ws/section1/topic151465.html |
