Sony KV-HR29M91
ashraf
ashraf
Сообщение #1 от 30/05/2010 02:13 цитата
Sony KV-HR29M91 Chassis AX-1
How can I recover this problem in a TV Sony KV-HR29M91
Note: I changed the FBT and the problem still exists
What causes this problem and how can I solve this?
  How to repair this problem in tv Sony KV-HR29M91_HR.rar  1.9 МБ  Скачано: 570 раз(а)
B.B.
Мастер
B.B.
Сообщение #2 от 30/05/2010 05:21 цитата
ashraf, Interest is framed in violation pravil. ----> http://monitor.espec.ws/section1/topic133974.html
P.S. Add firmware with this chassis
ashraf
ashraf
Сообщение #3 от 30/05/2010 16:10 цитата
Были отправлены firmware и ничего нового
Alexasha
Нелегал
Alexasha
Сообщение #4 от 30/05/2010 16:58 цитата
You must look for a faulty electrolytic capacitor
ashraf
ashraf
Сообщение #5 от 30/05/2010 19:12 цитата
Alexasha писал:
Survey efforts are described and found Onhamtabqp picture
Alexasha
Нелегал
Alexasha
Сообщение #6 от 30/05/2010 19:45 цитата
Perhaps in supply circuits, need search or replace all
goga_tv
goga_tv
Сообщение #7 от 30/05/2010 23:09 цитата
ashraf, I'm not sure that is defective block which you have shown in the figure. Find out what makes this effect. Block video, or horizontal scan.
Telik
Telik
Сообщение #8 от 30/05/2010 23:50 цитата
The defect was to replace FBT, or after? What voltage gives the power supply?
By defect recalls dead electrolyte in the power supply C8011, C8012-1500mkf\250v, or C6512-33mkf\160v.
B.B.
Мастер
B.B.
Сообщение #9 от 31/05/2010 06:17 цитата
ashraf, We need the firmware of the chassis and the photo board. Please publish it here in its theme. Thank you.
ashraf
ashraf
Сообщение #10 от 31/05/2010 14:37 цитата
Alexasha писал:
goga_tv писал:
ashraf , I'm not sure that is defective block which you have shown in the figure. Find out what makes this effect. Block video, or horizontal scan.
Telik писал:
By defect recalls dead electrolyte in the power supply C8011, C8012-1500mkf \ 250v, or C6512-33mkf \ 160v.
Изменены все конденсаторы
BB писал:
ashraf , We need the firmware of the chassis and the photo board. Please publish it here in its theme. Thank you.
KV-HR29M91_HR34M91 Ch.AX-1 schematic
  KV-HR29M91_HR34M91 Ch.AX-1 schematic.rar  3 МБ  Скачано: 536 раз(а)
Alexasha
Нелегал
Alexasha
Сообщение #11 от 31/05/2010 20:45 цитата
If you work without measurements - replacement driver
ashraf
ashraf
Сообщение #12 от 02/06/2010 01:12 цитата
Alexasha писал:
Поиск driver
Большое спасибо
G
