Sony Bravia KDL-40BX420
imran khan
imran khan
Сообщение #1 От 11/11/2014 20:01 цитата
Hello all friends
Nice to see you all again
I have above set in image problem like convergence type in CRT t.v also picture jumps slowly.
ДОБАВЛЕНО 11/11/2014 17:08
http://mlv-d1-p.mlstatic.com/7754-MLV5272947114_102013-O.jpg
Иван Зенин
Иван Зенин
Сообщение #2 От 11/11/2014 20:31 цитата
Defect of the LCD panel. Not repaired.
ДОБАВЛЕНО 11/11/2014 20:45
You can try to cut off signals SKV1, SKV2, SKV3, SKVB1, SKVB2, SKVB3, STVP
And Fill the composition of the TV.
imran khan
imran khan
Сообщение #3 От 12/11/2014 14:13 цитата
Thanks for help i will try to cut these lins
imran khan
imran khan
Сообщение #4 От 29/11/2014 17:32 цитата
Not working улыбка
imran khan
imran khan
Сообщение #5 От 30/11/2014 13:28 цитата
I cuts those lines but problem still remain the same.
Borek
Borek
Сообщение #6 От 30/11/2014 13:50 цитата
Иван Зенин
imran khan
imran khan
Сообщение #7 От 14/12/2014 06:30 цитата
Thanks all of you friends
Problem solved when i install used working panel from local market.
Mark as Solved.
111
33
33
