Cherry Tigo 4 прошивка ищется.
  Список форумов » Прошивки
gnom69
gnom69
Сообщение #1 От 07/11/2025 18:46 цитата
Процессор MCIMX6U6AVM08AC
Нанд MT29F8G08ABABA
По логу с ОС что то не так наверное.
В сети ничего нет , или плохо искал.
Зашитая МС приветствуется.
gnom69
gnom69
Сообщение #2 От 07/11/2025 19:19 цитата
Terminal log file
Date: 26.10.2025 - 13:49:34
U-Boot 2014.04 (Jan 10 2019 - 15:07:46
CPU: Freescale i.MX6DL rev1.3 at 792 MHz
CPU: Temperature 30 C, calibration data: 0x5a250b7d
Reset cause: POR
Board: MX6-Shinco revA
DRAM: 1 GiB
NAND: 1024 MiB
*** Warning - bad CRC, using default environment
Normal Boot
Press SPACE to abort autoboot in 0 seconds
mode is normal
NAND read: device 0 offset 0xa00000, size 0x550000
5570560 bytes read: OK
NAND read: device 0 offset 0x1200000, size 0x10000
65536 bytes read: OK
Kernel image @ 0x12000000 [ 0x000000 - 0x538880 ]
## Flattened Device Tree blob at 18000000
Booting using the fdt blob at 0x18000000
Using Device Tree in place at 18000000, end 1800e992
Starting kernel ...
of_dma_request_slave_channel: dma-names property missing or empty
spi_imx 2008000.ecspi: cannot get the TX DMA channel!
spi_imx 2008000.ecspi: dma setup error,use pio instead
fm1388_spi_probe
fm1388 reset successfully!
fm1388_spi_probe: max_speed = 25000000, chip_select = 0, mode = 0, modalias = fm1388_spi
fm1388_spi_init: spi_register_driver fm1388_spi_driver success. status = 0
DBG sensor data is at 809fbdc0
UBIFS error (pid 1): ubifs_check_node: bad CRC: calculated 0x9330fec5, read 0xd91b709b
UBIFS error (pid 1): ubifs_check_node: bad node at LEB 596:153432
magic 0x6101831
crc 0xd91b709b
node_type 1 (data node)
group_type 0 (no node group)
sqnum 295144
len 2308
key (8993, data, 27973)
size 4096
compr_typ 1
data size 2260
data:
00000000: 02 00 00 00 00 00 3d 10 00 01 10 38 f0 76 3d 88 00 20 05 7a 00 80 f3 27 1c 01 04 c4 21 df 7e 54
00000020: 01 e8 27 3c 00 00 2e 05 00 00 00 7a 00 00 00 68 f2 d5 72 f8 d7 d2 74 f0 25 df 7e 14 00 00 00 41
00000040: 6a e4 76 e0 d6 d5 72 0b 00 00 00 c4 91 8a 74 d5 19 ee 76 8c 21 df 7e 18 21 df 7e 10 6a e4 76 20
00000060: 21 df 7e b4 97 8a 74 6c 00 01 88 ef 97 74 7c 01 7c 00 60 12 6c 09 7c 0a 6c 01 03 01 00 00 00 10
00000080: 57 28 fc 01 6c 02 20 03 0c 00 01 8c 24 b0 74 7d 04 20 70 00 29 0c 00 03 36 00 00 00 ec 1c ac 03
000000a0: 08 80 21 df 7e 84 1b b0 74 e0 ac f1 9c 19 7c 02 7c 03 09 90 7d f3 76 10 00 00 00 aa 45 85 00 6c
000000c0: 01 00 01 00 80 f3 76 18 22 df 7e d0 de f2 76 c0 88 f3 76 e0 c6 f2 9c 05 78 0a 7c 14 03 e9 00 00
000000e0: 00 90 e1 bc 1f 09 7c 41 d7 74 1c 31 b0 74 08 6f d3 74 6c 17 6c 04 01 98 0c f3 76 7c 02 01 8c 22
00000100: df 7e 7c 08 00 01 e0 0a f3 76 20 22 df 7e 50 b5 a8 10 74 22 df 7e 30 b0 f1 9e 01 bc 8a bc 1c 6c
00000120: 09 7c 0a 6c 07 6c 08 7c 05 02 6e 66 6f 5f 32 60 02 31 0c 00 7c 0b f8 02 01 ff ff ff ff 6c 01 01
00000140: 7c 2b b0 74 7c 31 6c 01 20 07 0c 00 7c 35 04 4c 56 40 00 00 e0 d2 8c 27 6c 10 01 e4 8b 02 00 7c
00000160: 1f 05 ec 29 df 7e a0 fd f1 76 6c 13 6c 12 6c 03 fc 0a 6c 0d 6c 01 09 16 00 00 00 e8 67 0a 75 11
00000180: 00 00 00 2a 2c 00 01 e4 00 b1 74 2a 3c 00 7c 07 0d 9c 60 f0 74 60 23 df 7e 60 a2 18 01 00 02 00
000001a0: 00 7c 00 01 03 00 00 00 6c 03 01 c0 5f 89 74 6c 08 6c 0a 7d 01 15 60 03 cc 03 7c 01 7c 02 6c 00
000001c0: fc 45 6c 01 20 27 0c 00 2e bc 08 7d 0a 02 70 00 01 00 00 00 06 dc 00 27 18 00 01 90 4d 71 00 61
000001e0: 45 00 bc 17 2e 1c 03 01 20 d2 d5 72 ec 27 6c 06 0d 50 26 df 7e 84 72 92 74 94 72 92 74 10 00 0f
00000200: 80 6c 02 20 5f 0c 00 02 01 50 46 56 20 27 52 05 f0 7f 20 57 3c 02 7c 56 6c 00 bc 0f 09 f0 ff 9c
00000220: 0b 10 00 04 00 00 00 a4 7d b0 13 6c 01 00 01 3c ab e6 76 9c 06 e6 76 44 03 e6 76 1c 97 18 01 b4
00000240: 2f e5 27 1c 0e bc 06 2c 17 00 70 63 e4 37 7c 00 36 7c 01 07 b4 09 e6 76 60 04 e6 76 30 96 bc 0b
00000260: 04 f4 f6 e5 76 6c f3 e5 27 3e 00 c4 26 30 fc 13 00 02 57 03 00 00 88 f4 d5 72 a0 32 9c 74 0e 02
00000280: 00 00 64 66 e4 76 6c 0f fc 46 00 0c 18 4a f3 76 1f ee e3 76 8c 26 df 7e 18 26 df 7e 60 48 f3 76
000002a0: 20 26 df 7e 57 db 93 1c 74 26 df 7f 26 df 7e fc 7f 6c 09 fc 6b 74 1f 7c 05 2c 64 03 2c 34 00 7c
000002c0: 0b fc 50 ec 28 01 34 e1 86 74 7c 11 01 9c ba 91 5d 74 05 7c 6b fc 53 7c 12 2a 3c 00 7c 7e 7c 0c
000002e0: 7c 00 04 18 17 01 00 00 e0 e3 9c 26 6d 10 a3 6f 6f 80 f3 76 fc 7f 6c 13 6c 05 6c 03 7c 0a 60 76
00000300: 6c 0d 6c 01 6c 1e 7e 00 f0 f4 76 00 00 00 fc 01 9c 60 a8 02 27 4c 00 7c 09 09 e4 28 e4 76 ec 72
00000320: e4 76 64 6a e4 76 6c c2 c9 04 00 ec 01 06 61 70 70 2d 68 6c 75 70 67 e0 03 20 f2 1c 00 7f d5 c4
00000340: ab 86 9c b5 04 50 28 df 7e d4 9d 86 9c d9 fc 02 7c 00 7d 30 0f 2d ec 04 7c 02 fc 06 03 88 28 df
00000360: 7e 94 ab bc 06 78 04 7c 05 7c 03 6c 01 20 07 0c 00 7c 05 fc 09 01 d8 28 df 7e 7f 01 68 61 d3 9c
00000380: 12 04 e8 28 df 7e 8c 58 d3 9d 12 0d 22 af 20 61 d3 74 7c 03 6c eb 05 13 00 00 00 53 d1 98 06 6c
000003a0: 01 6e a5 80 29 38 9d 1d 0c 73 05 00 00 00 7c e1 06 6d b7 00 00 98 b5 d4 74 50 63 14 a0 99 74 22
000003c0: 9c 21 7c 52 78 01 ed 00 68 c0 01 00 09 39 00 00 00 5b 00 00 00 6e 00 00 00 77 00 00 00 7c 00 00
000003e0: 00 30 a2 99 74 a4 56 98 9c 13 e3 b1 dc a4 99 9c 09 7c 60 05 78 6d 18 01 c8 97 31 71 7c 14 fc 18
00000400: 02 b0 29 df 7e c8 dc 18 68 0b 7c 02 7c 03 6c 17 7c 61 01 8f 7a 2b 07 7c 01 7c 02 7c 03 03 e0 29
00000420: df 7e 3c 55 bc 1e 7c 01 7c 02 7c 03 7c 05 6f 15 b4 42 c8 27 7e 21 78 2a 38 de 03 38 12 74 07 bc
00000440: 1e 01 02 31 f5 6d 7c 1e 01 88 e4 f3 6d 6c 08 64 03 01 10 5e 30 71 7c 02 01 ec 2a df 7e 7c 08 0b
00000460: 58 5c 30 71 80 2a df 7e 81 56 08 19 d4 2a bc 8b 7c 01 fc 8b 6c 06 7c 15 7c 00 6c 08 7c 05 01 18
00000480: 93 d4 74 7c 2a 6c 02 03 78 04 f3 76 fc 2a 24 8c 24 7c 01 7f 0b f8 98 d3 9c 03 7c 8b 7e 29 e8 84
000004a0: bc 05 09 f8 f0 31 00 a0 bd 31 71 34 52 13 75 6c 09 01 4c 2d 32 71 7c 00 0d e0 bc 31 71 24 50 13
000004c0: 75 30 52 13 75 d4 10 da 74 7c 00 7c 2a 05 2c 3c 0c 00 00 b0 f3 6d 7c 0a 6f 10 6a c2 00 23 7c 21
000004e0: 7c 01 22 7c 21 7c 00 7c 07 6c 03 6c 01 01 b4 a4 99 74 6c 0d 0d 48 4f 13 75 bc f9 ff 6d 18 33 13
00000500: 75 9c da f4 74 7c 02 7c 04 6c 04 7f 02 00 a0 99 8c 39 2a 5c 00 08 24 28 f8 6d e0 66 30 71 68 a0
00000520: 89 8d 03 b8 dc 00 01 c0 f2 87 74 7c 05 01 94 2c df 7e 7c ca 03 c4 0f 01 00 f8 f1 bc b7 7c 09 6c
00000540: 00 ec 98 6c 01 8c 00 25 0c 2c 04 83 27 06 62 bb fe 5e e8 4b 88 03 20 13 10 00 2a fc 09 02 18 8b
00000560: f3 76 40 7f 5a d6 d5 72 7c 2b 22 4b 21 04 2e 87 9c b7 6f 0b 14 ba 8d 9c 17 6c 01 ef 1e 18 00 00
00000580: 9c e3 6c b9 04 cc 79 da 74 7c 20 94 23 be 2d b8 46 64 61 64 05 24 2e 25 d5 28 2c 7c 05 7c 1c 6c
000005a0: 08 6c 00 74 04 01 50 0a 03 00 6c 0d 01 a8 2c df 7e 7c 01 6c 00 2e ee 03 9c 68 28 bc 2b 2a 6c 00
000005c0: 09 1c f5 00 00 40 c1 01 00 0c 0e f2 76 6c 29 03 b4 2d df 7e e5 2d bc 08 fc 00 00 4c f2 2d df 7e
000005e0: fb 2d df 7e 10 2e df 7e 1e 2e df 7e 29 2e df 7e 37 2e df 7e 49 2e df 7e 64 2e df 7e 86 2e df 7e
00000600: 91 2e df 7e 9c 2e df 7e bd 2e df 7e f6 2e df 7e fc 2e df 7e 07 2f df 7e 16 2f df 7e 1f 2f df 7e
00000620: 31 2f df 7e 3d 2f df 7e 48 2f df 7e 4f 2f df 7e 57 2f df 7e 93 2f df 7e b6 2f ac 0d 7f 25 d7 b0
00000640: 08 24 7f 26 10 00 00 22 ec 28 01 64 00 00 00 6a d7 34 80 bc 24 22 5c 27 6c 4a 02 08 00 00 00 07
00000660: 73 1c 10 f1 76 6c 01 68 01 01 09 00 00 00 7c 1a e5 27 0c 73 02 00 00 00 6c 95 69 01 0e 70 00 01
00000680: 00 00 00 17 dc 00 0d 19 00 00 00 a0 2d df 7e 1f 00 00 00 dd 2f df 7e 6d ab b0 dc 1e c8 04 00 1a
000006a0: 00 a9 7d 01 87 c3 0c d9 1c fd 89 3a b2 95 1c 20 0c 76 37 6c 00 2f 6d 65 64 69 61 2f 6d 74 64 37
000006c0: 2f 61 70 70 6c 69 6e 6b 2f 62 69 6e 6c 01 00 92 2d 68 75 00 2d 70 6c 61 74 66 6f 72 6d 00 77 61
000006e0: 79 6c 61 6e 64 00 32 37 31 37 2c 66 66 34 30 2c 2d 31 00 6c 64 62 3d 73 69 6e 30 00 43 4f 4e 53
00000700: 4f 4c 45 3d 2f 64 65 76 2f 63 6f 6e 73 6f 6c 65 00 70 73 70 6c 61 73 68 3d 66 61 6c 73 65 00 54
00000720: 45 52 4d 3d 6c 69 6e 75 78 00 53 48 45 4c 4c 3d 2f 62 69 6e 2f 73 68 00 4c 43 5f 41 4c 4c 3d 7a
00000740: 68 5f 43 4e 2e 55 54 46 38 00 49 4e 49 54 5f 56 45 52 53 49 4f 4e 3d 73 79 73 76 69 6e 69 74 2d
00000760: 32 2e 38 38 00 50 41 54 48 3d 2f 75 73 72 2f 6c 6f 63 61 6c 6d 15 3a 98 01 01 62 69 6e 3a 74 01
00000780: 00 07 00 52 55 4e 4c 45 56 45 4c 3d 35 00 72 75 6e 6c 65 76 65 6c 3d 35 00 5f 3d 3d a4 03 00 40
000007a0: 47 53 54 5f 52 45 47 49 53 54 52 59 3d 2f 6d 6e 74 2f 64 61 74 61 31 2f 2e 67 73 74 72 65 61 6d
000007c0: 65 72 2d 30 2e 31 30 2f 72 65 67 69 73 74 72 79 2e 61 72 6d 2e 62 69 6e 00 50 57 44 3d 2f 00 56
000007e0: 45 52 42 4f 53 45 3d 6e 6f 00 45 44 49 54 4f 52 3d 2f 78 1b 00 10 76 69 00 54 5a 3d 43 53 54 2d
00000800: 38 00 46 42 5f 4d 55 4c 54 49 5f 42 55 46 46 45 52 3d 32 00 50 52 45 56 ac 15 00 92 4e 00 70 72
00000820: 65 76 69 6f 75 73 3d 4e 00 48 4f 4d 45 3d 2f 00 53 48 4c 56 4c 3d 34 00 44 42 55 53 5f 53 45 53
00000840: 53 49 4f 4e 5f 42 55 53 5f 41 44 44 52 45 53 53 3d 75 6e 69 78 3a 61 62 73 74 72 61 63 74 3d 2f
00000860: 74 6d 70 2f 64 62 75 73 2d 49 6b 4f 47 32 70 4b 74 6e 53 00 58 44 47 5f ff ff ff ff ff ff ff ff
00000880: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
000008a0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
000008c0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
UBIFS error (pid 1): ubifs_scan: bad node
UBIFS error (pid 1): ubifs_scanned_corruption: corruption at LEB 596:153432
UBIFS error (pid 1): ubifs_scanned_corruption: first 8192 bytes from LEB 596:153432
UBIFS error (pid 1): ubifs_scan: LEB 596 scanning failed
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
CPU1: stopping
CPU: 1 PID: 0 Comm: swapper/1 Not tainted 3.10.53-1.1.0_ga #1
[<80013bc0>] (unwind_backtrace+0x0/0xf4) from [<800115dc>] (show_stack+0x10/0x14)
[<800115dc>] (show_stack+0x10/0x14) from [<80012de8>] (handle_IPI+0x108/0x118)
[<80012de8>] (handle_IPI+0x108/0x118) from [<80008584>] (gic_handle_irq+0x58/0x5c)
[<80008584>] (gic_handle_irq+0x58/0x5c) from [<8000dd00>] (__irq_svc+0x40/0x70)
Exception stack(0xa8097f50 to 0xa8097f98)
7f40: a8097f98 00000002 b02f9787 00000000
7f60: afbdc582 00000000 8122f0e0 8094bdb4 00000001 00000000 a8096000 a8096000
7f80: 00000017 a8097f98 8005ff2c 804595dc 60000113 ffffffff
[<8000dd00>] (__irq_svc+0x40/0x70) from [<804595dc>] (cpuidle_enter_state+0x50/0xe0)
[<804595dc>] (cpuidle_enter_state+0x50/0xe0) from [<8045971c>] (cpuidle_idle_call+0xb0/0x148)
[<8045971c>] (cpuidle_idle_call+0xb0/0x148) from [<8000ed20>] (arch_cpu_idle+0x10/0x54)
[<8000ed20>] (arch_cpu_idle+0x10/0x54) from [<8005f800>] (cpu_startup_entry+0x104/0x150)
[<8005f800>] (cpu_startup_entry+0x104/0x150) from [<1069b9a4>] (0x1069b9a4)
------------[ cut here ]------------
WARNING: at kernel/time/tick-broadcast.c:600 tick_handle_oneshot_broadcast+0x1a8/0x1d0()
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.53-1.1.0_ga #1
[<800115dc>] (show_stack+0x10/0x14) from [<8002c5e8>] (warn_slowpath_common+0x54/0x6c)
[<8002c5e8>] (warn_slowpath_common+0x54/0x6c) from [<8002c69c>] (warn_slowpath_null+0x1c/0x24)
[<8002c69c>] (warn_slowpath_null+0x1c/0x24) from [<80067560>] (tick_handle_oneshot_broadcast+0x1a8/0x1d0)
[<80067560>] (tick_handle_oneshot_broadcast+0x1a8/0x1d0) from [<8001c044>] (mxc_timer_interrupt+0x38/0x40)
[<8001c044>] (mxc_timer_interrupt+0x38/0x40) from [<80079e0c>] (handle_irq_event_percpu+0x54/0x17c)
[<80079e0c>] (handle_irq_event_percpu+0x54/0x17c) from [<80079f70>] (handle_irq_event+0x3c/0x5c)
[<80079f70>] (handle_irq_event+0x3c/0x5c) from [<8007cca0>] (handle_fasteoi_irq+0x84/0x14c)
[<8007cca0>] (handle_fasteoi_irq+0x84/0x14c) from [<800795d4>] (generic_handle_irq+0x2c/0x3c)
[<800795d4>] (generic_handle_irq+0x2c/0x3c) from [<8000e9c8>] (handle_IRQ+0x40/0x90)
[<8000e9c8>] (handle_IRQ+0x40/0x90) from [<80008558>] (gic_handle_irq+0x2c/0x5c)
[<80008558>] (gic_handle_irq+0x2c/0x5c) from [<8000dd00>] (__irq_svc+0x40/0x70)
Exception stack(0xa8075d90 to 0xa8075dd8)
5d80: 00000000 00000000 00000101 a8074000
5da0: 00000202 0000001d 00000000 80940080 a8074000 80999370 ffffff8b 80931214
5dc0: 809da580 a8075dd8 800335dc 800335ec 20000113 ffffffff
[<8000dd00>] (__irq_svc+0x40/0x70) from [<800335ec>] (__do_softirq+0xc8/0x200)
[<800335ec>] (__do_softirq+0xc8/0x200) from [<800337b8>] (do_softirq+0x50/0x58)
[<800337b8>] (do_softirq+0x50/0x58) from [<80033a54>] (irq_exit+0x9c/0xd0)
[<80033a54>] (irq_exit+0x9c/0xd0) from [<8000e9cc>] (handle_IRQ+0x44/0x90)
[<8000e9cc>] (handle_IRQ+0x44/0x90) from [<80008558>] (gic_handle_irq+0x2c/0x5c)
Exception stack(0xa8075e68 to 0xa8075eb0)
5e60: 0004abeb ffffffff 00001e28 802705b8 0000005d 8095ab64
5e80: 00000000 000000c8 00000001 80999370 ffffff8b 80931214 00000000 a8075eb0
5ea0: 8069eca4 802705e4 20000113 ffffffff
[<8000dd00>] (__irq_svc+0x40/0x70) from [<802705e4>] (__loop_delay+0x0/0xc)
---[ end trace e063dbffefe87add ]---
Date: 26.10.2025 - 13:49:53
End log file
Другие темы раздела Прошивки
