Помогите найти драйвер для китайского монитора-телевизора
john28dv
30/06/2012 18:08
Всем привет! Помогите пожалуйста драйвером на китайский TFT-LCD монитор M-FAITH model MF-150. Больше ничего не известно. MonInfo пишет:
    Monitor
    Model name............... LG TV
    Windows description...... Модуль подключения монитора LG TV
    Manufacturer............. LGE
    Plug and Play ID......... GSM75A4
    Serial number............ 521530
    Manufacture date......... 2007, ISO week 5
    Filter driver............ None
    EDID revision............ 1.3
    Input signal type........ Digital
    Color bit depth.......... Undefined
    Display type............. RGB color
    Screen size.............. 700 x 390 mm (31,5 in)
    Power management......... Standby, Suspend, Active off/sleep
    Extension blocs.......... 1 (CEA-EXT)
    DDC/CI................... n/a
    Color characteristics
    Default color space...... Non-sRGB
    Display gamma............ 2,20
    Red chromaticity......... Rx 0,640 - Ry 0,341
    Green chromaticity....... Gx 0,287 - Gy 0,610
    Blue chromaticity........ Bx 0,146 - By 0,069
    White point (default).... Wx 0,285 - Wy 0,293
    Additional descriptors... None
    Timing characteristics
    Horizontal scan range.... 28-67kHz
    Vertical scan range...... 50-75Hz
    Video bandwidth.......... 150MHz
    CVT standard............. Not supported
    GTF standard............. Not supported
    Preferred timing......... Yes
    Native/preferred timing.. 1360x768p at 60Hz
    Modeline............... "1360x768" 84,750 1360 1432 1568 1776 768 771 776 798 -hsync +vsync
    Detailed timing #1....... 1280x768p at 60Hz
    Modeline............... "1280x768" 80,140 1280 1344 1472 1664 768 771 778 798 -hsync -vsync
    Standard timings supported
    720 x 400p at 70Hz - IBM VGA
    800 x 600p at 60Hz - VESA
    1024 x 768p at 60Hz - VESA
    800 x 600p at 60Hz - VESA STD
    1024 x 768p at 60Hz - VESA STD
    EIA/CEA-861 Information
    Revision number.......... 3
    IT underscan............. Supported
    Basic audio.............. Supported
    YCbCr 4:4:4.............. Supported
    YCbCr 4:2:2.............. Supported
    Native formats........... 1
    Detailed timing #1....... 1280x720p at 60Hz
    Modeline............... "1280x720" 74,250 1280 1344 1472 1664 720 723 728 748 +hsync +vsync
    Detailed timing #2....... 720x480p at 60Hz (4:3)
    Modeline............... "720x480" 27,000 720 736 798 858 480 489 495 525 -hsync -vsync
    Detailed timing #3....... 1440x480i at 60Hz (16:9)
    Modeline............... "1440x480" 27,000 1440 1478 1602 1716 480 488 494 524 interlace -hsync -vsync
    Detailed timing #4....... 1920x1080i at 60Hz (16:9)
    Modeline............... "1920x1080" 74,250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
    CE video identifiers (VICs) - timing/formats supported
    640 x 480p at 60Hz - Default (4:3, 1:1)
    720 x 480i at 60Hz - Doublescan (16:9, 32:27)
    720 x 576i at 50Hz - Doublescan (16:9, 64:45)
    720 x 480p at 60Hz - EDTV (4:3, 8:9)
    720 x 480p at 60Hz - EDTV (16:9, 32:27)
    720 x 576p at 50Hz - EDTV (4:3, 16:15)
    720 x 576p at 50Hz - EDTV (16:9, 64:45)
    1280 x 720p at 50Hz - HDTV (16:9, 1:1)
    1280 x 720p at 60Hz - HDTV (16:9, 1:1)
    1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
    1920 x 1080i at 60Hz - HDTV (16:9, 1:1) [Native]
    1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
    1920 x 1080p at 25Hz - HDTV (16:9, 1:1)
    1920 x 1080p at 30Hz - HDTV (16:9, 1:1)
    1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
    1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
    NB: NTSC refresh rate = (Hz*1000)/1001
    CE audio data (formats supported)
    LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
    CE speaker allocation data
    Channel configuration.... 2.0
    Front left/right......... Yes
    Front LFE................ No
    Front center............. No
    Rear left/right.......... No
    Rear center.............. No
    Front left/right center.. No
    Rear left/right center... No
    Rear LFE................. No
    CE vendor specific data (VSDB)
    IEEE registration number. 0x000C03
    CEC physical address..... 2.0.0.0
    Maximum TMDS clock....... 165MHz
    Report information
    Date generated........... 01.07.2012
    Software revision........ 2.60.0.972
    Data source.............. Registry
    Operating system......... 5.1.2600.2.Service Pack 3
    Raw data
    00,FF,FF,FF,FF,FF,FF,00,1E,6D,A4,75,3A,F5,07,00,05,11,01,03,80,46,27,78,EA,D9,B0,A3,57,49,9C,25,
    11,49,4B,81,08,00,01,01,01,01,01,01,45,40,01,01,61,40,01,01,01,01,1B,21,50,A0,51,00,1E,30,48,88,
    35,00,BC,88,21,00,00,1C,4E,1F,00,80,51,00,1E,30,40,80,37,00,BC,88,21,00,00,18,00,00,00,FC,00,4C,
    47,20,54,56,0A,20,20,20,20,20,20,20,00,00,00,FD,00,32,4B,1C,43,0F,00,0A,20,20,20,20,20,20,01,8F,
    02,03,23,F1,50,01,07,16,02,03,11,12,13,04,14,85,20,21,22,1F,10,23,09,07,07,83,01,00,00,65,03,0C,
    00,20,00,01,1D,00,80,51,D0,1C,20,40,80,35,00,BC,88,21,00,00,1E,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,
    00,13,8E,21,00,00,18,8C,0A,A0,14,51,F0,16,00,26,7C,43,00,C4,8E,21,00,00,98,01,1D,80,18,71,1C,16,
    20,58,2C,25,00,C4,8E,21,00,00,9E,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,9B
