john28dv
Всем привет! Помогите пожалуйста драйвером на китайский TFT-LCD монитор M-FAITH model MF-150. Больше ничего не известно. MonInfo пишет: Monitor
Model name............... LG TV
Windows description...... Модуль подключения монитора LG TV
Manufacturer............. LGE
Plug and Play ID......... GSM75A4
Serial number............ 521530
Manufacture date......... 2007, ISO week 5
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 700 x 390 mm (31,5 in)
Power management......... Standby, Suspend, Active off/sleep
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... n/a
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2,20
Red chromaticity......... Rx 0,640 - Ry 0,341
Green chromaticity....... Gx 0,287 - Gy 0,610
Blue chromaticity........ Bx 0,146 - By 0,069
White point (default).... Wx 0,285 - Wy 0,293
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 28-67kHz
Vertical scan range...... 50-75Hz
Video bandwidth.......... 150MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1360x768p at 60Hz
Modeline............... "1360x768" 84,750 1360 1432 1568 1776 768 771 776 798 -hsync +vsync
Detailed timing #1....... 1280x768p at 60Hz
Modeline............... "1280x768" 80,140 1280 1344 1472 1664 768 771 778 798 -hsync -vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
800 x 600p at 60Hz - VESA
1024 x 768p at 60Hz - VESA
800 x 600p at 60Hz - VESA STD
1024 x 768p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing #1....... 1280x720p at 60Hz
Modeline............... "1280x720" 74,250 1280 1344 1472 1664 720 723 728 748 +hsync +vsync
Detailed timing #2....... 720x480p at 60Hz (4:3)
Modeline............... "720x480" 27,000 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #3....... 1440x480i at 60Hz (16:9)
Modeline............... "1440x480" 27,000 1440 1478 1602 1716 480 488 494 524 interlace -hsync -vsync
Detailed timing #4....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74,250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
CE video identifiers (VICs) - timing/formats supported
640 x 480p at 60Hz - Default (4:3, 1:1)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 576p at 50Hz - EDTV (4:3, 16:15)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
1920 x 1080p at 25Hz - HDTV (16:9, 1:1)
1920 x 1080p at 30Hz - HDTV (16:9, 1:1)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 2.0.0.0
Maximum TMDS clock....... 165MHz
Report information
Date generated........... 01.07.2012
Software revision........ 2.60.0.972
Data source.............. Registry
Operating system......... 5.1.2600.2.Service Pack 3
Raw data
00,FF,FF,FF,FF,FF,FF,00,1E,6D,A4,75,3A,F5,07,00,05,11,01,03,80,46,27,78,EA,D9,B0,A3,57,49,9C,25,
11,49,4B,81,08,00,01,01,01,01,01,01,45,40,01,01,61,40,01,01,01,01,1B,21,50,A0,51,00,1E,30,48,88,
35,00,BC,88,21,00,00,1C,4E,1F,00,80,51,00,1E,30,40,80,37,00,BC,88,21,00,00,18,00,00,00,FC,00,4C,
47,20,54,56,0A,20,20,20,20,20,20,20,00,00,00,FD,00,32,4B,1C,43,0F,00,0A,20,20,20,20,20,20,01,8F,
02,03,23,F1,50,01,07,16,02,03,11,12,13,04,14,85,20,21,22,1F,10,23,09,07,07,83,01,00,00,65,03,0C,
00,20,00,01,1D,00,80,51,D0,1C,20,40,80,35,00,BC,88,21,00,00,1E,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,
00,13,8E,21,00,00,18,8C,0A,A0,14,51,F0,16,00,26,7C,43,00,C4,8E,21,00,00,98,01,1D,80,18,71,1C,16,
20,58,2C,25,00,C4,8E,21,00,00,9E,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,9B
