samsung 226cw had inverted picture | |
| imran khan 01/01/2013 21:23 |
Samsumg lcd monitor
Model.226cw Model code.Ls22mexsfvx Monitor Had invert picture like negative and i also note one more point that screen is white(should be black) with own OSD when i trun off the windows Xp. Now its looks sure faulty panel but for research i need to talk Tech friends on that i also seen in laptop screen. see picture below. I need service manua and need to know how to repair panel in this fault? |
| Lenchik 01/01/2013 22:03 |
OSD too a negative, or is normal?
Photograph the screen. Insert into the message. |
| TE 01/01/2013 22:09 |
http://monitor.espec.ws/section33/topic210440.html |
| imran khan 02/01/2013 00:41 |
osd also negative |
| imran khan 02/01/2013 02:11 |
Samsumg lcd monitor
| TE 02/01/2013 11:38 |
Measure the voltages on board LCD panel.
You do not know the Russian language? |
| imran khan 02/01/2013 13:20 |
Can you put here basic panel testing voltages?Did you know panel repairing? |
