samsung 226cw had inverted picture
  Список форумов » TFT-мониторы
imran khan
imran khan
Сообщение #1 От 01/01/2013 21:23 цитата
Samsumg lcd monitor
Model.226cw
Model code.Ls22mexsfvx
Monitor Had invert picture like
negative and i also note one more
point that screen is white(should be black) with own OSD when i trun off
the windows Xp.
Now its looks sure faulty panel but for
research i need to talk Tech friends on
that i also seen in laptop screen.
see picture below. I need service manua and need to know how to repair panel in this fault?
Lenchik
Lenchik
Сообщение #2 От 01/01/2013 22:03 цитата
OSD too a negative, or is normal?
Photograph the screen.
Insert into the message.
TE
Сообщение #3 От 01/01/2013 22:09 цитата
http://monitor.espec.ws/section33/topic210440.html
imran khan
imran khan
Сообщение #4 От 02/01/2013 00:41 цитата
osd also negative
imran khan
imran khan
Сообщение #5 От 02/01/2013 02:11 цитата
Samsumg lcd monitor
Model.226cw
the windows Xp.
inverted pic in all mode also in own osd picture is inverted
TE
Сообщение #6 От 02/01/2013 11:38 цитата
Measure the voltages on board LCD panel.
You do not know the Russian language?
imran khan
imran khan
Сообщение #7 От 02/01/2013 13:20 цитата
Can you put here basic panel testing voltages?Did you know panel repairing?
