сомнения от величины резистора R223 Монитор LG L173SA источн | |
| eletmoraes 18/06/2014 22:29 |
Monitor did not care before. Another technician placed a R223 resistor value 0.1 ohms and diode ZD260 S24 (?). I did some research and found that the correct diode is P6KE10A.
Board source code is: FSP045-2PI01 C251, C252 , C253 , C319 have been replaced. put the 10k resistor value and the diode P6KE10A, to turn the monitor lit the led on the power for only a moment to clear soon then repair the diode heats P6KE10A much. |
| KRAB 18/06/2014 22:43 |
вас ист дас?! |
