Viessmann Vitodens 100 FF error - Need firmware dump
nsizagreb
nsizagreb
Сообщение #1 От 23/02/2024 15:13 цитата
Need firmware for vitodens 100. The board in question always gives me the FF error.
I dont have a donor board to copy the firmware from.
The eprom chip type is 24LC64 as seen in the attached image in the signature below
anatol22
anatol22
Сообщение #2 От 23/02/2024 18:23 цитата
vitodens 100 - много разных плат применяется. Номер-на плате.
nsizagreb
nsizagreb
Сообщение #3 От 24/02/2024 11:00 цитата
Thanks
Number on board 7301071-2 SMT
Number on green label Viessmann 7425194
rommo
rommo
Сообщение #4 От 24/02/2024 11:49 цитата
Проверьте.
https://youtu.be/boJOkZYNm_E?si=M8Eb7S2JO17PN-p5
anatol22
anatol22
Сообщение #5 От 24/02/2024 12:16 цитата
прошивка
nsizagreb
nsizagreb
Сообщение #6 От 24/02/2024 12:25 цитата
anatol22 писал:
прошивка
Thank you
KDEL
Сообщение #7 От 08/10/2024 12:38 цитата
Greetings to everyone on the forum.
I have the same problem with the Vitodens 100 panel (FF error).
It is the exact same board as in the picture above.
Number on green label Viessmann 7425194.
Is it possible to get the content of eeprom 24LC64 again?
Thanks in advance.
Сообщение #8 От 08/10/2024 12:50 цитата
KDEL, .... недовольство, огорчение
KDEL
Сообщение #9 От 08/10/2024 12:58 цитата
Profile completed. классно!
KDEL
Сообщение #10 От 10/10/2024 22:38 цитата
I repeat the request for the correct content of eeprom 24LC64 of this board (@anatol22?).
Number on board 7301071-2 SMT.
Bar code label: 7455424185902204.
Attached is the current dump read from my board.
Thanks in advance and kind regards.
  24LC64_7301071-2 SMT.rar  2.17 КБ  Скачано: 329 раз(а)
Danik940102
Сообщение #11 От 23/10/2024 01:36 цитата
Need help, urgently. Please. We're freezing.
Need firmware for vitodens 100 WB1B
Eeprom 24LC64
Bar code label: 7455424207920100.
I think the board is not original because sticker on the boiler.
Thanks everyone in advance
  24lc64_WB1B_D.zip  2.36 КБ  Скачано: 265 раз(а)
  123.jpg  107.8 КБ  Скачано: 221 раз(а)
Сообщение #12 От 23/10/2024 13:39 цитата
Danik940102, .. недовольство, огорчение
Сообщение #13 От 23/10/2024 16:52 цитата
Danik940102, недовольство, огорчение
rainbowfish
Сообщение #14 От 21/12/2024 23:48 цитата
Тема не отмечена решенной и по этому набрался наглости пока тут спросить.
Имеется похожая проблема с Vitodens 100-W WB1C (Плата 7301071-3) появлением ошибки FF.
Но в моем случае она благополучно сбрасывается штатным способом, котел может работать день или два а может и чаc. Нет системы, начинают возникают перезагрузки и затем FF . Систему возникновения перезагрузок установить не удалось но, по наблюдениям в основном при переходе на ГВС.
Проверено электропитание и как можно исключены посторонние факторы которые могут давать наводки и помехи. Котел обслужен и ничего нового не добавлялось, что могло вызвать помехи.
На самой плате проверено питание пульсации (конденсатор в норме емкость и ЕСР) (он там один), реле на дребезг, следов окисления от влаги нет. Да и на столе работает штатно.
Вопрос. Прошивка еепром тут поможет или нет ?
Или искать другую причину. К сожалению нет такой платы заведомо исправной для проверки.
петроj
Сообщение #15 От 11/09/2025 13:45 цитата
Greetings to everyone on the forum. I have the same problem with the Vitodens 100 panel (FF error). It is the exact same board as in the picture above. Number on board 7301071-2 SMT Number on green label Viessmann 7425194. Is it possible to get the content of eeprom 24LC64 again? Thanks in advance. I can't go to the link to the file download page.
Сообщение #16 От 11/09/2025 14:11 цитата
петроj, .... недовольство, огорчение
