EZONETRONICS RM-CT0009 (AC8227) | |
| attack1975 23/04/2019 19:59 |
При включении моргает белым экраном 1 раз, при нажатии ресет тоже, пытаюсь прошить с sd карты в терминале выдает такое:
Build Time: Mar 29 2016 11:59:04 Init SD2 Card Send CMD0 Send CMD1 no response Send CMD8 Send CMD8 unkown Send ACMD41 SD Card Ready Send CMD2 Send CMD3 card type is 3,RCA is 0x7 Init SD2 Card Succuss eboot_img_des: dwLoadAddress:0x8fc60000 dwLoadPhyAddr:0x06f00000 dwJumpAddress:0x8fc60000 dwJumpPhyAddr:0x06f00000 dwStartAddr:0x00011000 dwdwTtlLen0x00080000 dramk , Mar 29 2016 11:59:07 dram setting version:ac8317 m1v1 v0.0 DC Balance OFF without Resistance Real frequency from PLL is 756 MHz DDR3, data rate: 1512 MHz. MEMPLL VCOCAL CPLT FLAG = 1; VCO STATE = 7 MEMPHYPLL A1 VCOCAL CPLT FLAG = 1; VCO STATE = 5 MEMPHYPLL AB VCOCAL CPLT FLAG = 1; VCO STATE = 5 MEMCTLPLL VCOCAL CPLT FLAG = 0; VCO STATE = 5 Support SSC set 0xA0[1]=1,0xBC[1]=1 ========== A1 PLL ========== delay tap= 0 DLINE=0 , count= 0 @ confidence=16 A1 PLL need to scan FBK delay delay tap= 1 DLINE=0 , count= 0 @ confidence=16 delay tap= 2 DLINE=2 , count= 2 @ confidence=16 A1 PLL calibration done! Final delay is 2 ========== AB PLL ========= delay tap= 0 DLINE=0 , count= 0 @ confidence=16 AB PLL need to scan FBK delay delay tap= 1 DLINE=2 , count= 6 @ confidence=16 AB PLL calibration done!Final delay is 1 ======== CTL PLL ======== delay tap= 0 DLINE=0 , count= 0 @ confidence=16 CTL PLL need to scan FBK delay delay tap= 1 DLINE=0 , count= 0 @ confidence=16 delay tap= 2 DLINE=0 , count= 0 @ confidence=16 delay tap= 3 DLINE=1 , count=16 @ confidence=16 CTL PLL calibration done!Final delay is 3 ================================= dramc_write_leveling_swcal ================================= byte_i status best delay 0 3 6 1 3 6 2 3 0 3 3 0 ======================== MIOCK jitter meter ======================== 1T = (81-17) = 64 delay cells =============================================== dqs input gating window, best delay value =============================================== best DQS0 Coarse 2T = 5 best DQS1 Coarse 2T = 5 best DQS2 Coarse 2T = 5 best DQS3 Coarse 2T = 5 _________________________________ best DQS0 Coarse 0.5T = 2 best DQS1 Coarse 0.5T = 2 best DQS2 Coarse 0.5T = 1 best DQS3 Coarse 0.5T = 1 _________________________________ best DQS0 fine tune = 1 best DQS1 fine tune = 1 best DQS2 fine tune = 25 best DQS3 fine tune = 27 ================================= ------------------------------------------------------ Start DQ delay to find pass range, DQS delay fixed to 0... ------------------------------------------------------ x-axis is bit #; y-axis is DQ delay (0~15) ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo xxooooooooooooooooooooxooooooooo xxoxoooooxooooooxooooxxooooooooo xxxxxxxoxxxoxxooxxxxxxxoxxooxooo xxxxxxxxxxxoxxxoxxxxxxxxxxooxoox xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx ------------------------------------------------------ Start DQS delay to find pass range, DQ delay fixed to 0... ------------------------------------------------------ x-axis is bit #; y-axis is DQS delay (1~15) ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooo----- AC8317 preloader v66573 ----- Build Time: Mar 29 2016 11:59:04 Init SD2 Card Send CMD0 Send CMD1 no response Send CMD8 Send CMD8 unkown Send ACMD41 SD Card Ready Send CMD2 Send CMD3 card type is 3,RCA is 0x7 Init SD2 Card Succuss eboot_img_des: dwLoadAddress:0x8fc60000 dwLoadPhyAddr:0x06f00000 dwJumpAddress:0x8fc60000 dwJumpPhyAddr:0x06f00000 dwStartAddr:0x00011000 dwdwTtlLen0x00080000 dramk , Mar 29 2016 11:59:07 dram setting version:ac8317 m1v1 v0.0 DC Balance OFF without Resistance Real frequency from PLL is 756 MHz DDR3, data rate: 1512 MHz. MEMPLL VCOCAL CPLT FLAG = 1; VCO STATE = 7 MEMPHYPLL A1 VCOCAL CPLT FLAG = 1; VCO STATE = 5 MEMPHYPLL AB VCOCAL CPLT FLAG = 1; VCO STATE = 5 MEMCTLPLL VCOCAL CPLT FLAG = 0; VCO STATE = 5 Support SSC set 0xA0[1]=1,0xBC[1]=1 ========== A1 PLL ========== delay tap= 0 DLINE=0 , count= 0 @ confidence=16 A1 PLL need to scan FBK delay delay tap= 1 DLINE=0 , count= 0 @ confidence=16 delay tap= 2 DLINE=0 , count= 0 @ confidence=16 delay tap= 3 DLINE=2 , count=13 @ confidence=16 A1 PLL calibration done! Final delay is 3 ========== AB PLL ========= delay tap= 0 DLINE=0 , count= 0 @ confidence=16 AB PLL need to scan FBK delay delay tap= 1 DLINE=2 , count= 6 @ confidence=16 AB PLL calibration done!Final delay is 1 ======== CTL PLL ======== delay tap= 0 DLINE=0 , count= 0 @ confidence=16 CTL PLL need to scan FBK delay delay tap= 1 DLINE=0 , count= 0 @ confidence=16 delay tap= 2 DLINE=2 , count= 4 @ confidence=16 CTL PLL calibration done!Final delay is 2 ================================= dramc_write_leveling_swcal ================================= byte_i status best delay 0 3 6 1 3 6 2 3 0 3 3 0 ======================== MIOCK jitter meter ======================== 1T = (81-17) = 64 delay cells =============================================== dqs input gating window, best delay value =============================================== best DQS0 Coarse 2T = 5 best DQS1 Coarse 2T = 5 best DQS2 Coarse 2T = 5 best DQS3 Coarse 2T = 5 _________________________________ best DQS0 Coarse 0.5T = 2 best DQS1 Coarse 0.5T = 2 best DQS2 Coarse 0.5T = 1 best DQS3 Coarse 0.5T = 1 _________________________________ best DQS0 fine tune = 2 best DQS1 fine tune = 1 best DQS2 fine tune = 26 best DQS3 fine tune = 25 ================================= ------------------------------------------------------ Start DQ delay to find pass range, DQS delay fixed to 0... ------------------------------------------------------ x-axis is bit #; y-axis is DQ delay (0~15) ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo xxooooooooooooooooooooxooooooooo xxoxoooooxooooooxooooxxooooooooo xxxxxxxoxxxoxoooxxxxxxxooxooxooo xxxxxxxxxxxoxxxoxxxxxxxxxxooxoox xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx ------------------------------------------------------ Start DQS delay to find pass range, DQ delay fixed to 0... ------------------------------------------------------ x-axis is bit #; y-axis is DQS delay (1~15) ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooooooooooooooooooooxooooooooo ooooxoooooooxoxxooooooxooooooooo ooooxxoxooxxxxxxooooooxooooooooo ooxxxxxxxxxxxxxxooooooxoooooooxo xxxxxxxxxxxxxxxxoxoooxxxoooxxxxo xxxxxxxxxxxxxxxxoxoxxxxxxxxxxxxx error on bit 22 ,setup_time =hold_time =0!! RX DQ/DQS calibration fail! ======================= DATLAT calibration ======================= DATLAT Default value = 0xc TAP= 8, err_value=0xffffffff, begin=0, first=255, sum=0 TAP= 9, err_value=0xffffffff, begin=0, first=255, sum=0 TAP=10, err_value=0xffffffff, begin=0, first=255, sum=0 TAP=11, err_value=0x 400000, begin=0, first=255, sum=0 TAP=12, err_value=0x 400000, begin=0, first=255, sum=0 TAP=13, err_value=0x 400000, begin=0, first=255, sum=0 TAP=14, err_value=0x 400000, begin=0, first=255, sum=0 TAP=15, err_value=0x 400000, begin=0, first=255, sum=0 no DATLAT taps pass Preloader Reboot is working now. И так бесконечно...Что может быть? |
| Goulbak 21/03/2021 16:56 |
[Привет,
У меня такой же аппарат и такая же проблема! Вы нашли решение ? |
