attack1975
При включении моргает белым экраном 1 раз, при нажатии ресет тоже, пытаюсь прошить с sd карты в терминале выдает такое:
----- AC8317 preloader v66573 -----
Build Time: Mar 29 2016 11:59:04
Init SD2 Card
Send CMD0
Send CMD1 no response
Send CMD8
Send CMD8 unkown
Send ACMD41
SD Card Ready
Send CMD2
Send CMD3
card type is 3,RCA is 0x7
Init SD2 Card Succuss
eboot_img_des:
dwLoadAddress:0x8fc60000
dwLoadPhyAddr:0x06f00000
dwJumpAddress:0x8fc60000
dwJumpPhyAddr:0x06f00000
dwStartAddr:0x00011000
dwdwTtlLen0x00080000
dramk , Mar 29 2016 11:59:07
dram setting version:ac8317 m1v1 v0.0
DC Balance OFF without Resistance
Real frequency from PLL is 756 MHz
DDR3, data rate: 1512 MHz.
MEMPLL VCOCAL CPLT FLAG = 1; VCO STATE = 7
MEMPHYPLL A1 VCOCAL CPLT FLAG = 1; VCO STATE = 5
MEMPHYPLL AB VCOCAL CPLT FLAG = 1; VCO STATE = 5
MEMCTLPLL VCOCAL CPLT FLAG = 0; VCO STATE = 5
Support SSC
set 0xA0[1]=1,0xBC[1]=1
========== A1 PLL ==========
delay tap= 0 DLINE=0 , count= 0 @ confidence=16
A1 PLL need to scan FBK delay
delay tap= 1 DLINE=0 , count= 0 @ confidence=16
delay tap= 2 DLINE=2 , count= 2 @ confidence=16
A1 PLL calibration done! Final delay is 2
========== AB PLL =========
AB PLL need to scan FBK delay
delay tap= 1 DLINE=2 , count= 6 @ confidence=16
AB PLL calibration done!Final delay is 1
======== CTL PLL ========
CTL PLL need to scan FBK delay
delay tap= 2 DLINE=0 , count= 0 @ confidence=16
delay tap= 3 DLINE=1 , count=16 @ confidence=16
CTL PLL calibration done!Final delay is 3
dramc_write_leveling_swcal
byte_i status best delay
0 3 6
1 3 6
2 3 0
3 3 0
MIOCK jitter meter
1T = (81-17) = 64 delay cells
dqs input gating window, best delay value
best DQS0 Coarse 2T = 5
best DQS1 Coarse 2T = 5
best DQS2 Coarse 2T = 5
best DQS3 Coarse 2T = 5
_________________________________
best DQS0 Coarse 0.5T = 2
best DQS1 Coarse 0.5T = 2
best DQS2 Coarse 0.5T = 1
best DQS3 Coarse 0.5T = 1
best DQS0 fine tune = 1
best DQS1 fine tune = 1
best DQS2 fine tune = 25
best DQS3 fine tune = 27
Start DQ delay to find pass range, DQS delay fixed to 0...
x-axis is bit #; y-axis is DQ delay (0~15)
ooooooooooooooooooooooxooooooooo
xxooooooooooooooooooooxooooooooo
xxoxoooooxooooooxooooxxooooooooo
xxxxxxxoxxxoxxooxxxxxxxoxxooxooo
xxxxxxxxxxxoxxxoxxxxxxxxxxooxoox
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Start DQS delay to find pass range, DQ delay fixed to 0...
x-axis is bit #; y-axis is DQS delay (1~15)
ooooo----- AC8317 preloader v66573 -----
Init SD2 Card
Send CMD0
Send CMD8
Send CMD8 unkown
Send ACMD41
SD Card Ready
Send CMD2
Send CMD3
eboot_img_des:
Support SSC
delay tap= 3 DLINE=2 , count=13 @ confidence=16
A1 PLL calibration done! Final delay is 3
delay tap= 2 DLINE=2 , count= 4 @ confidence=16
CTL PLL calibration done!Final delay is 2
0 3 6
1 3 6
2 3 0
3 3 0
MIOCK jitter meter
best DQS0 fine tune = 2
best DQS2 fine tune = 26
best DQS3 fine tune = 25
xxxxxxxoxxxoxoooxxxxxxxooxooxooo
ooooxoooooooxoxxooooooxooooooooo
ooooxxoxooxxxxxxooooooxooooooooo
ooxxxxxxxxxxxxxxooooooxoooooooxo
xxxxxxxxxxxxxxxxoxoooxxxoooxxxxo
xxxxxxxxxxxxxxxxoxoxxxxxxxxxxxxx
error on bit 22 ,setup_time =hold_time =0!!
RX DQ/DQS calibration fail!
DATLAT calibration
DATLAT Default value = 0xc
TAP= 8, err_value=0xffffffff, begin=0, first=255, sum=0
TAP= 9, err_value=0xffffffff, begin=0, first=255, sum=0
TAP=10, err_value=0xffffffff, begin=0, first=255, sum=0
TAP=11, err_value=0x 400000, begin=0, first=255, sum=0
TAP=12, err_value=0x 400000, begin=0, first=255, sum=0
TAP=13, err_value=0x 400000, begin=0, first=255, sum=0
TAP=14, err_value=0x 400000, begin=0, first=255, sum=0
TAP=15, err_value=0x 400000, begin=0, first=255, sum=0
no DATLAT taps pass
Preloader Reboot is working now.
И так бесконечно...Что может быть?
