MC9S12C96CPBE flash programing | |
| ALBABEN 04/08/2016 22:57 |
One can help to make recordings USBDM memory dump to read a Bosch MC9S12C96CPBE processor. Address for hcs08 processor is 1080-17FF and 182C-FFFF. HCS12 family while registrations do not know.
- I have a SIEMENS closed or not open the door. takes command button but not heard the beginning of the relay switch. the problem lies in MC9S12C96CPBE processor. I tried a board and works perfectly as washing. I changed my grief and processors from a slab to the next. the problem lies in the processor. Plates no problem. I deleted the errors that may have saved the classic way to make reset all errors of Bosch washing machines, but without result. - If it is not possible to read this firmware you can find a firmware fix for this processor? |
| Иван Василич 05/08/2016 05:39 |
ALBABEN, Адреса,не те (даташит в помощь),и вообще попробуйте работать с кодевариатором,там есть этот проц.
Почта |
| тю 12/08/2016 07:54 |
Иван Василич, какие адреса можно узнать ? |
