MC9S12C96CPBE flash programing
  Список форумов » Программаторы
ALBABEN
ALBABEN
Сообщение #1 От 04/08/2016 22:57 цитата
One can help to make recordings USBDM memory dump to read a Bosch MC9S12C96CPBE processor. Address for hcs08 processor is 1080-17FF and 182C-FFFF. HCS12 family while registrations do not know.
- I have a SIEMENS closed or not open the door. takes command button but not heard the beginning of the relay switch. the problem lies in MC9S12C96CPBE processor. I tried a board and works perfectly as washing. I changed my grief and processors from a slab to the next. the problem lies in the processor. Plates no problem. I deleted the errors that may have saved the classic way to make reset all errors of Bosch washing machines, but without result.
- If it is not possible to read this firmware you can find a firmware fix for this processor?
  2016-08-04 21.33.49.rar  363.53 КБ  Скачано: 337 раз(а)
Иван Василич
Иван Василич
Сообщение #2 От 05/08/2016 05:39 цитата
ALBABEN, Адреса,не те (даташит в помощь),и вообще попробуйте работать с кодевариатором,там есть этот проц.
Почта
тю
тю
Сообщение #3 От 12/08/2016 07:54 цитата
Иван Василич, какие адреса можно узнать ?
Другие темы раздела Программаторы
