HELP !!!! Philips 46pfl6605d Ambilight problem in SAM mode
mica123
Сообщение #1 От 03/10/2016 16:58 цитата
[FONT=Comic Sans MS]The model is 46pfl6605d/93
It is in the SAM mode ,Alignments , Ambilight option.
Sorry guys , I can't speak Russian . So please read English below.
I turned the "module 01" brightness down under 100 by mistake, but can't go back getting over 100.Now the light comes from the left side is darker than before. you can see the brightness is 212, which is over 100 in "module 02" and this is the original value.
Is there some way like adding some code to the "FacAligns.txt" then send it back to the TV? And , what code should be added?
I'll be more than grateful if you help me with this!!!
[/FONT]
[/img]
ДОБАВЛЕНО 03/10/2016 16:59
And this is how my FacAilgns.txt looks like
<swver>Q5521</swver>
<item>FacAlignWhiteRNormal</item>
<Xaddr>300</Xaddr>
<lastvalue>112</lastvalue>
<item>FacAlignWhiteGNormal</item>
<Xaddr>308</Xaddr>
<lastvalue>127</lastvalue>
<item>FacAlignWhiteBNormal</item>
<Xaddr>310</Xaddr>
<lastvalue>118</lastvalue>
<item>FacAlignWhiteRCool</item>
<Xaddr>318</Xaddr>
<lastvalue>102</lastvalue>
<item>FacAlignWhiteGCool</item>
<Xaddr>320</Xaddr>
<lastvalue>122</lastvalue>
<item>FacAlignWhiteBCool</item>
<Xaddr>328</Xaddr>
<item>FacAlignWhiteRWarm</item>
<Xaddr>330</Xaddr>
<lastvalue>125</lastvalue>
<item>FacAlignWhiteGWarm</item>
<Xaddr>338</Xaddr>
<item>FacAlignWhiteBWarm</item>
<Xaddr>340</Xaddr>
<lastvalue>81</lastvalue>
<item>FacAlignBlackLevelOffsetR</item>
<Xaddr>348</Xaddr>
<lastvalue>8</lastvalue>
<item>FacAlignBlackLevelOffsetG</item>
<Xaddr>34c</Xaddr>
<item>FacAlignMainAnaIfAgcTOP</item>
<Xaddr>350</Xaddr>
<lastvalue>64</lastvalue>
<item>FacAlignAuxAnaIfAgcTOP</item>
<Xaddr>358</Xaddr>
<item>FacAlignAuxAnaIfAgcTOPPos</item>
<Xaddr>360</Xaddr>
<lastvalue>28</lastvalue>
<item>FacAlignMainAnaIfAgcTOPPos</item>
<Xaddr>368</Xaddr>
<item>WhiteRCustom</item>
<Xaddr>378</Xaddr>
<item>WhiteGCustom</item>
<Xaddr>380</Xaddr>
<item>WhiteBCustom</item>
<Xaddr>388</Xaddr>
<item>BlackLevelOffsetGCustom</item>
<Xaddr>390</Xaddr>
<item>BlackLevelOffsetRCustom</item>
<Xaddr>394</Xaddr>
<item>TunerIfGainCalibrationLow</item>
<Xaddr>398</Xaddr>
<item>TunerIfGainCalibrationMid</item>
<Xaddr>3a0</Xaddr>
<item>TunerIfGainCalibrationHigh</item>
<Xaddr>3a8</Xaddr>
1
