TV repair Samsung LE32M87BD chassis GTU32HEN, problem DC / D
imran khan
imran khan
Сообщение #1 От 15/01/2013 12:58 цитата
chassis GTU32HEN, problem DC / DC
Description of the Problem When the standby LED will flash,
sounds musical screensaver, but the
light does not appear, the TV starts a
new attempt to start and this goes on for about 3 minutes. At some point,
begins to work inverter and a picture of this type: Visually "bloated" capacitors in the power supply is not visible. Output
voltages correspond to the scheme,
the control pulses of crime is not
revealed.
Composition chassis GTU32HEN: MAIN: BN63-02494A
Tuner: DN0S403MH26
SGTV5810C
BA7657F
T-CON: T315XW02 VF
PSU: BN44-00156B MC33067P
STR-A6159
INVERTOR: T315XW02 VF
F10V0411-01
SUB BOARD: BN41-00895B
BN94-01382B Nature of the problem has changed
over time, which has led to the
assumption of the capacitive nature of the defect. The first were tested DC / DC converters MAIN Board, but their voltage match circuit. Wings on the board defect Submodule SUB Board: S6108_FRC was faulty capacitor in a DC / DC on board BN41-00895B: Was discovered by unsustainable ripple 3 pin. IC6007 L4931CDT33,
nominal 1 uF. Repair has been reduced to the
replacement of the component. The
efficiency of the TV recovered after
replacement. Perhaps the service manual for this model will be useful in the repair of Samsung televisions in the chassis GTU32HEN
<br />ripple 3 pin. IC6007 L4931CDT33,
<br />nominal 1 uF
vebs
Белгородец
Сообщение #2 От 15/01/2013 15:41 цитата
imran khan, сколько эта твоя хрень с не русским языком будет продолжаться?
Ты типа не уважаешь русский? Тогда шагай на английский форум! В чужом монастыре со своими правилами?
Скачай прогу переводчика и переводи, прежде чем тут писать. Думайте сами ...
Торгаш !!! http://translate.google.ru/translate?hl=ru&sl=en&u=http://lcddata.webs.com/&prev=/search%3Fq%3Dimran_usa9%2540yahoo.com%26hl%3Dru%26newwindow%3D1%26tbo%3Dd%26biw%3D800%26bih%3D503&sa=X&ei=wE71UMO9D8WUswa3zoHICA&sqi=2&ved=0CFoQ7gEwBQ
Раз продаешь инфу по ремонту, так не лезь на бесплатный русскоязычный форум мастеров, со своим английским форматом.
УЧИСЬ УВАЖАТЬ ЛЮДЕЙ , К КОТОРЫМ ПРИШЕЛ!
imran khan
imran khan
Сообщение #3 От 15/01/2013 16:32 цитата
I dont want to hurt you people any more.
vebs
Белгородец
Сообщение #4 От 15/01/2013 16:39 цитата
Vais au bains avec l'anglais! Думайте сами ...
snoopy
Учу ТВ летать
Учу ТВ летать
Сообщение #5 От 15/01/2013 17:00 цитата
vebs писал:
vebs, Извини, но ты неправ! подмигивание 9. Писать сообщения разрешается только на русском или английском языках. В первом случае в качестве набора знаков должна использоваться кириллица, во втором - латиница. Если у вас нет возможности писать на кириллице, но вы хотите оставить сообщение на русском языке, используйте функцию "Русская клавиатура".
http://monitor.espec.ws/info/rules.html
vebs
Белгородец
Сообщение #6 От 15/01/2013 17:09 цитата
snoopy, заполню создам пару тем на английском. Будешь читать? Правила правилами , а я писал про УВАЖЕНИЕ! И потом, он темы создает не с вопросами а с решениями. А что там в правилах написано? Его нужно перемещать в Энциклопедию.Раз уж правила ты так соблюдаешь ,то переноси темы куда нужно http://monitor.espec.ws/section31/topic122783.html
snoopy писал:
Все у него есть. Издевается и не более.
imran khan писал:
Уважаемые участники форума, я
хочу узнать от вас людей, а также
поделиться тем, что я есть классно!
МЕДАЛЬ ЕМУ дай! смех За то что один ...по правилам пишет на английском, а десятки ребят потом трахаются с переводчиками.
Yuritsh
Yuritsh
Сообщение #7 От 15/01/2013 17:26 цитата
vebs, не наезжай на человека. Он тебе не конкурент.
vebs
Белгородец
Сообщение #8 От 15/01/2013 17:28 цитата
Yuritsh, улыбка ты про ТС? Устал переводить его темы. Может он там пишет хрень антисимисткую. А я как порядочный гражданин должен быть бдительным! улыбка
Yuritsh
Yuritsh
Сообщение #9 От 15/01/2013 17:30 цитата
Да.
Если кто-то отвечает на английском, это тоже польза. Попрактиковаться в английском никому не вредно. А не хочешь - не отвечай. Прошел мимо, да и всё.
vebs писал:
За этим есть кому следить.
Я тоже на болгарском форуме по русски спрашивал. Ничего, ответили, не надорвались. И не возмущались.
vebs
Белгородец
Сообщение #10 От 15/01/2013 17:37 цитата
Сергей.
Ему тогда нужно объяснить куда свои темы девать. Например сюда. http://monitor.espec.ws/section31/topic122783p60.html
Ты прав. Пусть строчит. улыбка
Administrator
ЕСпецовед
ЕСпецовед
Administrator
Сообщение #11 От 15/01/2013 18:15 цитата
Сообщение Администрации :
Внимание!
Использование английского языка на форуме разрешено правилами.
Using English on the forum is allowed by the rules.
Nik_Al
Старый таёжник
Старый таёжник
Сообщение #12 От 15/01/2013 20:53 цитата
vebs писал:
imran khan, Скачай прогу переводчика и переводи, прежде чем тут писать. Думайте сами ...
Ладно, так и быть - сделаю это за него улыбка
Ремонт телевизоров Samsung LE32M87BD
Шасси GTU32HEN, проблема DC / DC
Описание проблемы, когда ожидания светодиод будет мигать,
Звучит музыкальная заставка, но
свет не появится, ТВ начинается
Новая попытка начать, и это продолжается в течение примерно 3 минут. В какой-то момент,
начинает работать преобразователь и картины этого типа: Визуально "раздутой" конденсаторы в блоке питания не видно. выходной
напряжения соответствуют схеме,
управляющие импульсы преступления не
выявлено.
Состав шасси GTU32HEN: MAIN: BN63-02494A
Тюнер: DN0S403MH26
SGTV5810C
BA7657F
T-CON: T315XW02 VF
Блок питания: BN44-00156B MC33067P
STR-A6159
ИНВЕРТОР: T315XW02 VF
F10V0411-01
SUB СОВЕТ: BN41-00895B
BN94-01382B Характер проблемы не изменилось
с течением времени, что привело к
Предположение о емкостного характера дефекта. Первые были протестированы DC / DC преобразователи основной плате, но их напряжение холостого хода матча. Крылья на плате субмодуля дефект SUB совет: S6108_FRC был неисправный конденсатор DC / DC на борту BN41-00895B: было обнаружено неустойчивой пульсации 3-контактный разъем. IC6007 L4931CDT33,
номинальная 1 мкФ. Ремонт был сокращен до
Замена компонента.
Эффективность телевизора восстановилась после
замена. Возможно, инструкции по эксплуатации для данной модели будет полезна при ремонте телевизоров Samsung на шасси GTU32HEN
imran khan
imran khan
Сообщение #13 От 16/01/2013 15:19 цитата
Thank you admin
imran khan
imran khan
Сообщение #14 От 16/01/2013 16:34 цитата
Thanks all who support me
And love you all.
Oleg-44
Сообщение #15 От 16/01/2013 17:08 цитата
Да вот эта тема, только на русском языке.http://tvrepair.ru/neispravnosti/132-remont-samsung-le32m87bd.html
vebs
Белгородец
Сообщение #16 От 16/01/2013 19:36 цитата
imran khan писал:
And love you all.
Fsglilgk Iw sdfmn, i asjkfjlo jys? бяка
Бакум
Рождённый в СССР
Рождённый в СССР
Сообщение #17 От 16/01/2013 20:13 цитата
Еще одна тучка..... смех
B.B.
Мастер
B.B.
Сообщение #18 От 17/01/2013 18:02 цитата
Administrator писал:
Жаль, что о тупом плагиате ничего не написано в правилах.
Содрал в наглую все с другого сайта и хотябы на аглицком намек на источник. бяка бяка бяка
mehanik.57
Сообщение #19 От 30/05/2013 00:14 цитата
Ну, разобрались. Когда этот дефект встретился во второй раз, я решил разместить материал о нем на своем сайте http://tvrepair.ru/. Не думал, что буду читать этот текст на английском.
vebs
Белгородец
Сообщение #20 От 30/05/2013 06:53 цитата
Скоро и на Китайском напишут.
