LG Шасси LD33B
moroz.v
23/09/2014 06:13
LG 32LA621V-ZD Шасси LD33B
MATRIX: LC320DUE (SF) (U1)
MAIN: EAX64797003(1.2)
NAND flash: стикер SAA36403530 VER.03.11.03
H5TQ4G63AFR x2
H5TQ2G63AFR
NTP7513
Tuner: EBL61240503 TSQ-G601D(B)
T-CON: LC500DUE-SFR1 P/N 6870C-0452A
TL2354EP
TPS65178A
TPS6598
PSU & LED Driver: EAX64881301(1.6)
3BR4765JZ
SC1S311
NR891D
BD9483F
20NF20
19NF20
MDF11N65B
MBRF10U200CT x2
ТЕМЫ С НЕИСПРАВНОСТЯМИ:
Borek
21/12/2014 14:19
LG 32LN570V-ZE Шасси LD33B
MATRIX: LC320DUE (SF)(R1)
Tuner: TDSQ-G601D(B)
T-CON: LC500DUE-SFR1_Control-Merge P/N: 6870C-0452A
PSU: EAX64905001(2.7)
SK352A
NR891D
MAP3202
4NF20L
20NF20
Remote: AKB73715601
Borek
06/05/2015 17:19
LG 47LA660V-ZA ARUZLH Шасси LD33B
MATRIX: LC470EUH (PF)(P1)
MAIN: EAX64697006(1.0)
Tuner: TDSQ-G601D(B) EBL61240503
T-CON: LC470EUG-PFF1 LEFT P/N:6870S-1581A & LC470EUG-PFF1 RIGHT P/N:6870-S-1582A
Bluetooth: IA6948-00 BM-LDS401 P/N:EBR763663001
WI-FI: TWFM-B006D
IR: EBR76384101
Subwoofer: EAB62809601
PSU & INVERTOR: LGP4247-13LPB P/N: EAY62810901
Remote: AKB73715601 & Magic AN-MR400
Borek
21/06/2015 13:12
LG 50LA620V-ZA.ARUYLH Шасси LD33B
MATRIX: LC500DUE (SF)(U1)
MAIN: EAX64797004(1.1)
T-CON: LC500DUE-SFR1_Control_Merge 6870C-0452A
LG5831
WI-FI: TWFM-B006D
PSU & LED Driver: EAX64905501(2.3)
Borek
13/08/2015 16:00
LG 32LA620V-ZA.ARUYLH Шасси LD33B
M,ATRIX: LC320DUE (SF)(U1)
MAIN: NC4_M_TU24 EAX64797004(1.1) EBT62637201
Tuner: TDSQ-G601D(B) EBBL61240503
WI-FI: TWFM-B006D
IR: YWDOV90000A EBR76485801
KEY: YWDM590000A EBR76384101
PSU: LGP32-13PL2 EAX641301(1.7)
Remote: AKB73756502
LG 32LA620V-ZA, шасси LD33B как войти в сервис
Borek
10/10/2015 17:58
LG 42LN570V-ZE Шасси LD33B
MATRIX: LC420DUE (SF)(R3)
MAIN: EAX64797004(1.1) EBT62345912
PSU: LGP42-13PL1 EAX64905301(2.3)
fodis
06/01/2017 00:02
LG 42LA660V-ZA.BRUYLJU Шасси: LD33B
MATRIX: LC420EUG(PF)(F1)
MAIN: EBT62596109 (EAX64797004(1.1)
CPU под радиатором
IC702 - H5TQ2G63DFR
IC701, IC703 - H5TQ4G63AFR
IC8100 - THGBM5G5A1JBAIR
Tuner: EBL61240503 / TDSQ-G601D(B)
WI-FI: EAT61813901 TWFM-B006D
Bluetuth: EBR76363001 IA6948-00 BM-LDS401
IR: EBR76405601 LA66 IR Ver1.1
PSU & LED Driver: LGP4247L-13LPB EAY62810901 EAX64905701 (2.3)
0133 / D2J5 SO-8
SSC9527S
iW7011-00 / R1FAL
100BCA / 246AZ0Z
Сервис мануал
Схема LGP4247L-13LPB
Обойти защиту блока питания LG
fodis
03/06/2017 19:40
LG 55LA660V-ZA.BRUZLJU Шасси LD33
MATRIX: LC550EUH(PF)(P1)
MAIN: EBR76823179 EAX64797003(1.2)
Tuner: EBL61240503 (TDSQ-G601D(B))
KEY: EBR76384101
IR: EBR76405601 (LA66 IR Ver1.1)
BLUETOOTH: EBR76363001 IA6948-00 BM-LDS401
LOGO LED: EBR76381901
ПОДСВЕТКА: 6916L1209B (55" V13 ART TV REV0.1 2 L-Type) + 6916L1210B (55" V13 ART TV REV0.1 2 R-Type) на общем радиаторе 6922L-0069A
PSU: LGP55-13LPB EAX64905801(1.9)
ДИНАМИКИ:
Осн: EAB62829101 8 Ом 10/14W
Саб: EAB62809601 10Ом 10/14W
Remote: AKB73756502
lg 55la660v-za - Включается и гаснет
SONATA186
08/06/2017 16:01
LG 42LA620V-ZA Шасси LD33B
MATRIX: LC420DUE(SF)(1U)
MAIN: EBR76823129 EAX64797003(1.2)
cpu-под радиатором
IC701-D9PXV
IC703-D9PXV
IC702-D9PTK
IC2405-54327
IC8100-NAND flash: стикер SAA36403538 VER.3.20.33/SAA36403809 VER 3.01.1
IC2404-RT8289
IC3000-100GEA
IC5400-NTP7513
IC6100-TPA6138
IC6900-A8303
T-CON: 6870C-0452A
UC1-TL2354EP_S
U3-TPS65198
U2-SW4051D
PSU & LED Driver: EAX64905401(1.6)
IC501-3BR4765JZ
Q601-13NM60N
IC801-BD9483F
IC101-SSC9527S
Remote: AKB73756502
LED LG 42LA620V Нет подсветки
LED LG 42LA620V - проблема с портами
Borek
24/01/2018 02:34
LG 32LA660V-ZA.ARUZLH Шасси LD33B
MATRIX: LC320EUB(PF)(P1)
MAIN: EAX64797004(1.1) NC4_M_TU24 EBT62596165
LED Driver: PPW-LE32TM-O(A) 6917L-0132A
Плата с модулем Bluetooth: P/N:EBR76363001
PSU: LGO32-13P EAX64907901(2.4)
Remote: AKB73715601
Borek
05/03/2018 17:50
LG 47LA644V-ZA LD33B
MATRIX: LC470EUN (SF)(F2)
MAIN: EBR76823104 EAX64797003(1.2)
T-CON: LC470DUE-SFR1_Control_Ver 1.0 6870C-0444A
LED Driver: PCLH-D201 A REV 07 6917L-0117A
WI-FI: TWFM-B006D
KEY: EBR76405782
Планки: 6870S-1500A LC470EUN-SFF1 LEFT Source Ver 1.0 H/F & 6870S-1501A LC470EUN-SFF1 RIGHT Source Ver 1.0 H/F
PSU: LGP4755-13P EAX64908101(2.2)
