как прошить BIOS? | |
| DRAKULA666 03/05/2012 19:44 |
подскажите ребята как прошить BIOS на ноутбуке LENOVO G555, роскажите пошагово. Потомучто невидно нефига на экране
Зарание спасибо. |
| SBA 03/05/2012 21:45 |
Легко - программатором |
| FANTASTRON 03/05/2012 22:20 |
Flash BIOS update - Flash from Operating System version for G455 G555
Version 2CCN21WW Installation README Updated Date:2010-5-20 This package updates the basic input/output system (BIOS) on G455 G555. BIOS, abbreviation of Basic InputЈЇOutput System, is integrated in ROM chip on main board, which contains the basic input/output program, system configuration information, system startup self-check and pre-setup programs. BIOS provides most basic low-level hardware operations; it is the connection between software and hardware, and interfacing window of hardware and operating system. Note: Make note of any settings you have changed in the BIOS Configuration Utility. These settings may have to be re-entered after updating the BIOS. Attention: Do not power off or restart your computer during the BIOS flashing process, which will cause serious damage and improper functioning of your computer. Print this file so that you can refer to it during the installation. Downloading the package ======================= 1. Click on the file link to download the file from the web page. 2. When prompted, select a drive and directory in which to save the downloaded file. Installing the package in Windows. ====================== 1. Locate the file NAWA1110.exe that has been downloaded. 2. Double click the NAWA1110.exe icon. 3. Click install 4. Click flash bios 5. Press Enter to start flashing. During the flashing process, you are advised not to turn off the computer. 6. When the update finishes, the computer will automatically reboot for the changes to take effect. Updated Information: The Latest BIOS Version supports ATI M93 XT graphics card. Summary of changes ================== General Information: Trademarks ========== IdeaPad and IdeaCentre are registered trademarks of Lenovo. Microsoft and Windows are trademarks of Microsoft Corporation in the United States, other countries, or both. Other company, product, and service names may be trademarks or service marks of others. THIS DOCUMENT IS PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND. WE DISCLAIM ALL WARRANTIES, WHETHER EXPRESS OR IMPLIED, INCLUDING WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF FITNESS FOR A PARTICULAR PURPOSE AND MERCHANTABILITY WITH RESPECT TO THE INFORMATION IN THIS DOCUMENT. BY FURNISHING THIS DOCUMENT, WEGRANT NO LICENSES TO ANY PATENTS OR COPYRIGHTS. Copyright (c) Lenovo 2008, all rights reserved http://support.lenovo.com/en_US/downloads/default.page? |
| ДядяЮра 03/05/2012 22:32 |
DRAKULA666, Потомучто невидно нефига на экране
А причем здесь Bios???? |
| n max 04/05/2012 01:33 |
бывает и из-за биоса на асерах сталкивался |
| Lenchik 04/05/2012 06:45 |
А я сталкивался (почти каждый день) видяху угробли, в 3D игры играли. Либо греть на инфракрасной станции либо чип менять. |
| DRAKULA666 04/05/2012 17:08 |
подскажите плиз, можно ли греть на обичной паяльной станции видюху, если да то при какой температуре? |
| Sergej 04/05/2012 19:57 |
DRAKULA666, греть можно, только если хочется добить материнку.
Искать дефект надо, и далеко не факт что дело в ГК, север тоже надёжностью не отличается, да и БИОС я бы прошил до шаманств с мостами. Может к Мастеру, пока не поздно? |
| DRAKULA666 05/05/2012 00:41 |
у нас толковых мастеров нету... бабло срубят и потом некого еб*** не будет... |
| Sergej 05/05/2012 02:18 |
DRAKULA666, ищи тут ближайшего Мастера, или того из них, кто по почте работает, по крайней мере не испортят |
| Batix 05/05/2012 23:08 |
Ребята ну до смешного доходет ну опустите свои глазки на 7 постов ниже! Я вам всё обяснил - зачем создавть новые темы сам на эти грабли наступил LENOVO легко програмируется флешка (если это на 100% BIOS) |
| DRAKULA666 06/05/2012 13:26 |
http://monitor.espec.ws/section34/topic198923.html |
| Chernig0v 06/05/2012 21:50 |
Как вариант - http://lenovofans.ru/86-vosstanovlenie-bios-pri-neudachnoj-proshivke.html |
