DRAKULA666
подскажите ребята как прошить BIOS на ноутбуке LENOVO G555, роскажите пошагово. Потомучто невидно нефига на экране
Зарание спасибо. |
SBA
FANTASTRON
Flash BIOS update - Flash from Operating System version for G455 G555
Version 2CCN21WW
Installation README
Updated Date:2010-5-20
This package updates the basic input/output system (BIOS) on G455 G555.
BIOS, abbreviation of Basic InputЈЇOutput System, is integrated in ROM chip on main board, which contains the basic input/output program, system configuration information, system startup self-check and pre-setup programs. BIOS provides most basic low-level hardware operations; it is the connection between software and hardware, and interfacing window of hardware and operating system.
Note: Make note of any settings you have changed in the BIOS Configuration Utility. These settings may have to be re-entered after updating the BIOS.
Attention: Do not power off or restart your computer during the BIOS flashing process, which will cause serious damage and improper functioning of your computer.
Print this file so that you can refer to it during the installation.
Downloading the package
1. Click on the file link to download the file from the web page.
2. When prompted, select a drive and directory in which to save the downloaded file.
Installing the package in Windows.
1. Locate the file NAWA1110.exe that has been downloaded.
2. Double click the NAWA1110.exe icon.
3. Click install
4. Click flash bios
5. Press Enter to start flashing. During the flashing process, you are advised not to turn off the computer.
6. When the update finishes, the computer will automatically reboot for the changes to take effect.
Updated Information:
The Latest BIOS Version supports ATI M93 XT graphics card.
Summary of changes
General Information:
Trademarks
IdeaPad and IdeaCentre are registered trademarks of Lenovo.
Microsoft and Windows are trademarks of Microsoft Corporation in
the United States, other countries, or both. Other company, product,
and service names may be trademarks or service marks of others.
THIS DOCUMENT IS PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND.
WE DISCLAIM ALL WARRANTIES, WHETHER EXPRESS OR IMPLIED,
INCLUDING WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF FITNESS
FOR A PARTICULAR PURPOSE AND MERCHANTABILITY WITH RESPECT TO THE
INFORMATION IN THIS DOCUMENT. BY FURNISHING THIS DOCUMENT, WEGRANT
NO LICENSES TO ANY PATENTS OR COPYRIGHTS.
Copyright (c) Lenovo 2008, all rights reserved
http://support.lenovo.com/en_US/downloads/default.page? |
ДядяЮра
DRAKULA666, Потомучто невидно нефига на экране
А причем здесь Bios???? |
| бывает и из-за биоса на асерах сталкивался |
Lenchik
| А я сталкивался (почти каждый день) видяху угробли, в 3D игры играли. Либо греть на инфракрасной станции либо чип менять. |
DRAKULA666
| подскажите плиз, можно ли греть на обичной паяльной станции видюху, если да то при какой температуре? |
Sergej
DRAKULA666, греть можно, только если хочется добить материнку.
Искать дефект надо, и далеко не факт что дело в ГК, север тоже надёжностью не отличается, да и БИОС я бы прошил до шаманств с мостами.
Может к Мастеру, пока не поздно? |
DRAKULA666
| у нас толковых мастеров нету... бабло срубят и потом некого еб*** не будет... |
Sergej
| DRAKULA666, ищи тут ближайшего Мастера, или того из них, кто по почте работает, по крайней мере не испортят |
Batix
| Ребята ну до смешного доходет ну опустите свои глазки на 7 постов ниже! Я вам всё обяснил - зачем создавть новые темы сам на эти грабли наступил LENOVO легко програмируется флешка (если это на 100% BIOS) |
DRAKULA666
Chernig0v
