ashraf
B.B.
ashraf
| Были отправлены firmware и ничего нового |
Alexasha
| You must look for a faulty electrolytic capacitor |
ashraf
| Alexasha писал: | | You must look for a faulty electrolytic capacitor |
Survey efforts are described and found Onhamtabqp picture
Alexasha
| Perhaps in supply circuits, need search or replace all |
goga_tv
| ashraf, I'm not sure that is defective block which you have shown in the figure. Find out what makes this effect. Block video, or horizontal scan. |
Telik
The defect was to replace FBT, or after? What voltage gives the power supply?
By defect recalls dead electrolyte in the power supply C8011, C8012-1500mkf\250v, or C6512-33mkf\160v. |
B.B.
| ashraf, We need the firmware of the chassis and the photo board. Please publish it here in its theme. Thank you. |
ashraf
| goga_tv писал: | | ashraf , I'm not sure that is defective block which you have shown in the figure. Find out what makes this effect. Block video, or horizontal scan. |
| Telik писал: | The defect was to replace FBT, or after? What voltage gives the power supply?
By defect recalls dead electrolyte in the power supply C8011, C8012-1500mkf \ 250v, or C6512-33mkf \ 160v. |
Изменены все конденсаторы
| BB писал: | | ashraf , We need the firmware of the chassis and the photo board. Please publish it here in its theme. Thank you. |
KV-HR29M91_HR34M91 Ch.AX-1 schematic
KV-HR29M91_HR34M91 Ch.AX-1 schematic.rar 3 МБ Скачано: 647 раз(а)
Alexasha
| If you work without measurements - replacement driver |
ashraf
| Alexasha писал: | | If you work without measurements - replacement driver |
Поиск driver
Большое спасибо |
