Philips 21GR1251/22B шасси GR1AX
B.B.
14/02/2009 08:59
Philips 21GR1251/22B шасси GR1AX / Philips 142021IR/14B, 142821IR/14B, 14GR1021/02B, 14GR1021/05B, 14GR1021/10B, 14GR1021/16B, 14GR1021/22B, 14GR1021/57R, 14GR1021/57X, 14GR1021/59H, 14GR1022/87R, 14GR1023/67B, 14GR1024/50B, 14GR1024/50R, 14GR1024/57R, 14GR1024/59R, 14GR1024/75R, 14GR1033/65, 14GR1033/67R, 14GR1033/68R, 14GR1034/50R, 14GR1034/55R, 14GR1034/57R, 14GR1034/75R, 14GR1034/79R, 14GR1220/05B, 14GR1220/08B, 14GR1220/10B, 14GR1220/11B, 14GR1220/11E, 14GR1220/11G, 14GR1220/16B, 14GR1220/22B, 14GR1220/50B, 14GR1220/54B, 14GR1220/57B, 14GR1220/59H, 14GR1220/73B, 14GR1220/75B, 14GR1220/77B, 14GR1220/79B, 14GR1220/85B, 14GR1220/97B, 14GR1221/02B, 14GR1221/02W, 14GR1221/05B, 14GR1221/05V, 14GR1221/05W, 14GR1221/07B, 14GR1221/08B, 14GR1221/10B, 14GR1221/10V, 14GR1221/10W, 14GR1221/15B, 14GR1221/16B, 14GR1221/16L, 14GR1221/16V, 14GR1221/16W, 14GR1221/22B, 14GR1221/32B, 14GR1221/32V, 14GR1221/42B, 14GR1221/42V, 14GR1221/43B, 14GR1221/57L, 14GR1221/57R, 14GR1221/57W, 14GR1221/59R, 14GR1221/75R, 14GR1222/87R, 14GR1223/50B, 14GR1223/79B, 14GR1224/50B, 14GR1224/50R, 14GR1224/57R, 14GR1224/59H, 14GR1224/75R, 14GR1224/79R, 14GR1225/08B, 14GR1225/10B, 14GR1225/15B, 14GR1225/16B, 14GR1227/02B, 14GR1227/05B, 14GR1227/05W, 14GR1227/07B, 14GR1227/08B, 14GR1227/10B, 14GR1227/10W, 14GR1227/15B, 14GR1227/16B, 14GR1227/42B, 14GR1228/50R, 14GR1228/54R, 14GR1228/75R, 14GR1228/77R, 14GR1228/84R, 14GR1228/85R, 14GR1228/97R, 14GR1229/05B, 14GR1229/10B, 14GR1229/16B, 14GR1230/50R, 14GR1230/57R, 14GR1230/70R, 14GR1233/65, 14GR1233/67R, 14GR1233/68R, 14GR1234/50R, 14GR1234/52R, 14GR1234/54R, 14GR1234/57R, 14GR1234/58, 14GR1234/58R, 14GR1234/59H, 14GR1234/59R, 14GR1234/62R, 14GR1234/73R, 14GR1234/75R, 14GR1234/77, 14GR1234/77R, 14GR1234/79R, 14GR1234/85, 14GR1234/85R, 14GR1234/87R, 14GR1236/50, 14GR1236/50R, 14GR1236/52, 14GR1236/52R, 14GR1236/54R, 14GR1236/57, 14GR1236/57R, 14GR1236/58, 14GR1236/58R, 14GR1236/59, 14GR1236/59H, 14GR1236/59R, 14GR1236/62R, 14GR1236/65, 14GR1236/67R, 14GR1236/68, 14GR1236/68R, 14GR1236/70, 14GR1236/75, 14GR1236/75R, 14GR1236/77, 14GR1236/77R, 14GR1236/79R, 14GR1236/79R, 14GR1236/85, 14GR1236/85R, 14GR1236/87R, 14GR1239/50R, 14GR1239/59H, 14GR1239/65R, 14PT121A/05, 14PT121A/05W, 14PT121A/10, 20GR1250/02B, 37KV1232/22B
Клоны: Phonola 37KV1232/08B
СХЕМА шасси GR1AX (1,19 MB)
ПРОШИВКА на шасси GR1AX подмигивание
СОСТАВ ШАССИ:
Micom - TMP47C434N-3415
Memory - 24C02
SMPS - BUK446
SAW - OFW G1961
Secam - TDA3592A
PAL - TDA3565
Video - TDA8305
Vertical - даташит на TDA3653B
Sound - TDA7052
Tuner - 3139 147 10731 UV917E/PHONO SV20
Band - LA7910
Tube - A51EAM32X45
FBT - 37622TY (HR7527)
HOT - 2SC3795 (2SC3353, BUT11AF, 2SC4518)
RGB Amp. - даташит на BF422
Пульт: - RC-8201, RC-8211
IC remote - PCA8521F
ТЕМЫ С НЕИСПРАВНОСТЯМИ:
Нет звука
Иногда не включается Секам
Проблемы с БП
Нет высокого
Нет настройки
Не запускается строчная
