Philips 20CT6350/58 шасси CTO-93 (CTO-S)
Petr57
Сообщение #1 От 16/08/2010 11:10 цитата
Philips 20CT6350/58 шасси CTO-93 (CTO-S) / Philips 14CT6015, 14CT6017, 14CT6018/73, 14CT6020, 14CT6415, 14CT6416, 14CT6420, 16CT6025, 16CT6026, 16CT6425, 16CT6426, 20CT6020, 20CT6050, 20CT6051, 20CT6160, 20CT6250, 20CT6350, 20CT6360/56R, 20CT6363, 20CT6450, 20CT6451, 20CT6550, 20CT6750, 20CT6753, 20CT6760, 20CT93E, 21CT9460, 21CT9651, 21CT9760, 21CT9763, 21CT9952, 21CT9952/75Z, 21CT9953, 22AV1200, 25CT9085, 26CT6070, 26CT6470, 26CT6770, 37KT6200, 42KT6250, 42KT6254, 42KT6260, 51KT6500, 51KT6502,
СХЕМА шасси CTO-93 (CTO-S)
МАНУАЛ шасси CTO-93 (CTO-S)
ПРОШИВКА на шасси CTO-93 (CTO-S)
ВХОД В СЕРВИСНОЕ МЕНЮ
СОСТАВ ШАССИ:
Main -
Micom - M5840A-87
Memory - MSM2128-20
SMPS -
TR Chopper -
SAW -
Secam - TDA3590A
PAL - TDA3561A
NTSC - TDA3563A
VIF - TDA3541
Vertical - TDA3651AQ
Sound - даташит на TDA2611AQ
SIF - TBA120AS
Tuner - UV411
TV/AV -
Tube -
FBT -
HOT - даташит на 2SD1577
RGB Amp. - BF583
Пульт: -
IC remote -
Other ICs - HEF4556BP, TDA2577A, LM339DP, N74LS164N, SAA5230/V3, SAB3013, SAB439
ТЕМЫ С НЕИСПРАВНОСТЯМИ:
V
