imran khan
Grundig 30LW76-4501
Chassis L4
Anyone has a schematic of power
board Please,R82,R41,R42,&Q7 burnt
beyond recognition,any help is
welcome.
Уважаю спецов
Человек с пакистана пишет на сей форум, на английском пишет, ищет схему на телик, кто поможет? Пипец аж с пакистана! |
eduard2
imran khan,chassis BEKO -L4 30inch This power adapter 15V / 4A? |
imran khan
Уважаю спецов Thank you for explain my words in forum..
A friend of mime from U.k ask me about the schmatic of grunding lcd tv power supply.
Can any one help me here?
ДОБАВЛЕНО 06/05/2013 01:04
R82,R41,R42,& Q7
i need value of above |
Уважаю спецов
Не зашто imran khan, Но сомневаюсь што кто то здесь тебе поможет, долгое молчание это доказывает, eduard2, Вы начали неплохо, помогите человеку |
RAMMER
imran khan писал: | Grundig 30LW76-4501
Chassis L4
| mran khan , foto power supply . Нужны фотографии блока питания с двух сторон . |
imran khan
eduard2 help me a lot here and other friends too..i do not have pictures of above power supply. |
igor.phoenix
Юный радиолюбитель
imran khan, so what? Make photos both sides yourself.
ДОБАВЛЕНО 07 Май 2013, 01:20
We need know main compound of your power board. |
eduard2
imran khan, well the board has any inscriptions? (And I'm not talking about what a driver is, and what the key to this adapter?) I understand flew key (FET) resistors (current sensors) and if so then the driver (PWM) also spoiled sense to look for the scheme? the more I do not, my advice is buy a new adapter, or use a donor with the same parameters such (and write in Russian) |
imran khan
Thank you for supporting me here.
imran khan
Grundig 30WLB500Sas the IC is
FA13843 r82 is 1k r41 is47ohms r42 is
10k also Q7 smd code 1P is an
2N2222Aand the power fet on the top
of the board is a n channel 06N80C3 all burnt. |
