sdancer75
Hi,
Since I don't know any Russians and I used an automated translation app to read those posts I am not sure If I understand well.
I have almost the same symptoms in my Bosch refrigerator, and as I understand the problem was the regulator 9C05L that it should output -5V. A reply after 2 years of the original post, recommend to replace this part with 79L05CPK.
http://monitor.espec.ws/section24/topic261854.html
So my question. It was indeed the voltage regulator 9C05L the actual problem ? How much voltage should 9C05L output ?
Best Regards
shadow dancer |
sdancer75, заполняйте Профиль... |
AlexW2
Hi, sdancer75.
9C05L = 7905.
Instead of -5V was -1.9V - the processor is to blame. |
sdancer75
Hi Alex,
So to understand the problem was the 9C05L regulator or the processor itself ?
Regards,
ДОБАВЛЕНО 11/05/2017 21:28
xarl писал: | sdancer75, заполняйте Профиль... |
I don't know Russians so I can not find the options so easy ! I am sorry ! |
AlexW2
The voltage drop across 9C05L only the consequences of a broken CPU. At least in this thread. |
aleko081
