imran khan
SONY LCD
Had problems
1.works good without sound no audio
2.System Hang after 3 to 5 min running.
3.some times hangs R.C and front panel when chanage chanals with tac sound and also picture wash out with laft side broken imgae type.
Its looks frimware or els?
Klv3.jpg 83.59 КБ Скачано: 790 раз(а)
Freez klv.jpg.jpg 174.85 КБ Скачано: 720 раз(а)
Klv3.jpg 83.59 КБ Скачано: 679 раз(а)
Fix klv.rar 825.89 КБ Скачано: 702 раз(а)
semvictor
System hang is frimware problem.So some times hangs R.C and front panel and picture wash out..Change frimware and . |
imran khan
| Ok, where i found firmware software? |
semvictor
| Сan anyone have it-asking...(not everyone understands you-what is a problem). |
semvictor
| Does anyone on the forum has access to the site office, ask them. |
Иван Зенин
| imran khan, а я думаю ПО здесь не причём. Возможно звуковой процессор по шине не отвечает, вот и зависает телек.Состав бы выложил,легче общаться было бы. |
imran khan
| You are right, might be the bus chain command does not addresing micon with sound processor? |
Иван Зенин
| Yes,exactly this I had in view of. |
imran khan
| I very much like you people and i like to laern russain |
imran khan
| And yes frimware will help me if problem remain. |
imran khan
I visited many web sites of the world, but really you boys did very good job here,
hates off  |
semvictor
imran khan
| Where i found frimware software of above model or any similer one? |
БУНЯ
Верный друг сайта
imran khan
Thanks for link
I am posting regarding the issue of tv,This was my luck that same models came to my work shop this month,the first one fix by replacing the subsitute tuner
The 2nd one came with freezing fault,i post photos of above fault too
Now i did the every trick in 2 days what all friend say but its hard luck to remain unsolve mistry.
I want to upgrade frimware but could not find it.
A friend of mine in sony company says you should replace the main board and its cost PKR 10,000 |
Иван Зенин
imran khan
Idont like board replacement,you all gather here for component lelevel repair and very few people did this job..Hates off to you all.  |
semvictor
| Google turns translating nonsence.Especially Hates off to you all. |
imran khan
Caps off i mean to say
Google Translation not too good.
Set fix by using dump of 32s550a
And reballing method on main chip.
I will up load video |
imran khan
| i want to up load faulted tv video and after repaired tv video,please let me know where i can. |
