Yuritsh
Thomson 29DX25KG шасси ICC17 / Thomson 21DG22E, 21DK24E, 21DK24E1, 21DK24U, 21DP210G, 21DU21C, 21DU21E, 21DU22C, 21DU22E, 21DU24E, 21DX210S, 21DX25E, 21DX25EA, 21DX25ES, 21MT21E, 21MT22E, 24WK21E, 24WK22E, 24WK24E, 24WK25EG, 24WT25E, 25DG16E, 25DG16ET, 25DG17KG, 25DG21E, 25DG22E, 25DG25EG, 25DG25ES, 25DH21E, 25DH22E, 25DT21E, 25DT22E, 25DU21E, 25DU24E, 25DX210S, 25DX25ES, 25DX25KG, 25DX25KH, 25MH21E, 25MN16ET, 28DF21E, 28DF22E, 28DG16E, 28DG16ET, 28DG21E, 28DG22E, 28DG23K, 28DG24E, 28DK24E, 28DK25E, 28DK25ES, 28DK26ED, 28DN20E, 28DN22E, 28DP25EG, 28DP25ES, 28DT21E, 28DT22E, 28EX22E, 28VK24U, 28VK25E, 28VK25EG, 28VK25ES, 28VK26UW, 28WD210S, 28WF25E, 28WF25EG, 28WF25ES, 28WH200S, 28WN22E, 28WR23EG, 28WS21E, 28WS22E, 28WS24E, 28WS26EW, 28WT25ES, 28WT25ST, 28WX210S, 28WZ210S, 29DF25EB, 29DF25EG, 29DF25EL, 29DF25ER, 29DF25ES, 29DF25KG, 29DF25KH, 29DH21E, 29DH22E, 29DJ24E, 29DJ25EG, 29DL200G, 29DL21E, 29DL22C, 29DL22E, 29DL24E, 29DL25ED, 29DU21E, 29DU22E, 29DX210KH, 29DX210KP, 29DX210S, 29DX25ES, 29DZ210S, 29MH21E, 29MH22E, 32VK24U, 32VK25E, 32VK25EG, 32VK25ES, 32WF200G, 32WF25E, 32WF25EG, 32WF25ES, 32WH210S, 32WN22E, 32WS21E, 32WS23E, 32WS24E, 32WS26EW, 32WS26NW, 32WT210S, 32WX210S, 33MF22E, 33MF22EG, 33MS21E, 33MS24E, 33MS24EG, 33MS25UD
Клоны: Brandt 70210S2, 70W212S / Ferguson M8422U, W7022U / Saba M5518C, M5518E, M6322C, M7022E, M8521E, M8522C, M8522E, T7022C, W7021E, W7022E / Telefunken DF222C, DF316ET, DF316ET2, DF322C, DF322E, DF416ET, DF416ET2, DF422E, DS521E, DS521EF, DS522EF, MF222C, MF622E
СХЕМА TV Thomson 28DG23K шасси ICC17 (4.89 MB)
СХЕМА шасси ICC17 (0.64 MB)
ПРОШИВКА на шасси ICC17
ВХОД В СЕРВИСНОЕ МЕНЮ
СОСТАВ ШАССИ:
Micom - 92R195B9Q0/JAM
Memory - 24C16 6 (SMD)
EPROM - S031638 Thomson ICC17/ALL
SMPS - TS3702C & BUW1215
SAW - K6282K & даташит на K9650M
TR Chopper - RR5 40322-98 10537860
Reset & Reg - даташит на TDA8139
Video - TDA8855H
Vertical - даташит на TDA8351
Sound - TDA7269
Stereo - MSP34116 A2 ?
Tuner - CTF5510A 21130310
Tube - A68ELA011X001
FBT - 40330-68 10781320 (HR8846) / 40330-66 (HR80066) ? / 40330-54 HR8549
HOT - BUH516TH
RGB Amp. - TDA6107JF
Пульт: - RCT-2100
IC remote - M21007210
RCCreator - 042231B0E33576C7947
ТЕМЫ С НЕИСПРАВНОСТЯМИ:
Поиски схемы
27 ошибка
27 ошибка, узкая полоса
Не включается из дежурки
Замена ТДКС
Беспрестанно мигает красный светодиод
Глюки управления
Нет строчных импульсов
"Перезагружается"
Невозможно войти в сервис
Проблема с изображением
Фото со стороны дорожек.rar 195.56 КБ Скачано: 2178 раз(а)
