Универсальный цифровой пробник на PIC контроллере 17 функций
На страницу 1, 2, 3, 4  След.
m.ix
Master Mixa
m.ix
Сообщение #1 От 18/05/2010 04:05 цитата
Super Probe 17in 1
SuperProbe 17in one
http://members.cox.net/berniekm/super.obj прошивка
http://members.cox.net/berniekm/super.src сурс
http://members.cox.net/berniekm/pic93.zip
Логический пробник
Частотомер
счётчик импульсов
диодный пробник
измеритель ёмкости
генератор
генератор видеосигнала NTSC
генератор сервосигналов
и остально тут
http://members.cox.net/berniekm/super.html
1 Prob
- Logic Probe
The logic probe shows 'H' for high (over 3.7 volts), 'L' for low (below 0.8 volts) and '-' for floating in the first display location. If a pulse is detected (0.5 usec minimum), the second location flashes a 'P'.
2 PULS
- logic pulser
The logic pulser shows the pulse rate (5, 50, 500, 5.0) in the last 3 locations. The first location shows the sensed logic level as a dash in the bottom or top of the digit. When button #1 is held down, a series of 0.5 microsecond pulses are generated in the opposite direction and the center segment is lit. Pushing button #2 cycles thru the 4 pulse rates. The selected pulse rate is saved on power down.
3 FrEq
- Frequency Counter
In the frequency counter mode, hitting button #1 switches the display to the next 4 digits of the count. For instance, the display shows '12.57' for a frequency of 12,576 hz. Holding down button #1 shows '2576' - the lowest 4 digits. If a decimal point shows, the value is in Khz, if the decimal is flashing, the value is in Mhz. Hence, a frequency of 42,345,678 hz is displayed as 42.34 with a flashing decimal. Holding down button #1 in this case will display 5678.
4 Cnt
- Event Counter
In the event count mode, the display shows the lowest 4 digits. Button #1 switches to the next higher 4 digits while held down. Button #2 resets the count.
5 VoLt
- Voltmeter
The voltmeter uses the power going into the probe as a voltage reference. The current implementation shows only an approximate voltage - about 2% high. This can still be very usefull for most measurements. Do not connect the probe to voltages that exceed 5 volts under any conditions.
6 diod
- Diode Junction Voltage
This is just the voltmeter function with 10k resitor feeding current to the probe tip. When a diode or transistor junction is connected from the tip to the ground lead, the drop voltage is displayed.
7 Cap
- Capacitance Measurement
When a capacitor is connected from the tip to the ground lead, and button #1 is pushed, its value is displayed. Values from .001 uf to about 500 uf are displayed. The larger the capacitor, the longer it takes to measure. A value of 100uf takes a couple of seconds.
8 Coil
- Inductance Measurement
When an inductorr is connected from the tip to the ground lead, and button #1 is pushed, its value is displayed. Values from 0.1 to 999.9 millihenries are displayed. Note: this function assumes that the DC resistance is not more than a few ohms. Also, if the unit gets 'stuck' in this mode, jumper the tip to ground to free it.
9 SIG
- Signal Generator
This mode generates a 500hz squarewave at about 0.5 volts. The signal is only generated while button #1 is held down.
10 ntSC
- Video Patern
Generates an NTSC video frame with a white dot pattern when button #1 is held down.
11 9600
- Serial Ascii
Each time button 1 is pushed, the letters A-Z followed by cr/lf is generated. Auto polarity sensing. If the signal injection point is orignally high, then normal (zero start bit) ascii is generated. Otherwise, the other polarity is done. New feature: Button #2 cycles thru 1200, 2400, 4800, 9600 baud.
12 Midi
- Midi Note
Sends note number 60 (middle C) on any of the 16 midi channels. Holding button 1 sends 'note on'. Release of button 1 sends 'note off'. Buttton 2 cycles thru the 16 channels. The midi channel number is stored.
13 R/C
Servo
Generates 1ms to 2ms pulse for r/c servos. Button 1 increases pulse, Button 2 decreases pulse. Defaults to 1.5 ms each time mode is entered.
14 [ ]
Sqaure Wave
Generates 1 - 9999 hz squarewave. Button 1 decreases frequency, Button 2 increases frequency.
15 Prn
- Pseudo Random Number
Generates 10khz digital PRN series.
16 ir38
Generates 1 millisecond on and 2.5 millisecond off of 38khz square wave. When connected to IR LED, used for testing IR reciever modules.
17 PWM
Generates variable pulse width 3-97 percent of a 6khz (approx) digital signal. Button 1 decreases pulse width, Button 2 increases pulse width.
http://320volt.com/pic16f870-ile-17-fonksiyonlu-test-ve-olcum-probu/
http://320volt.com/wp-content/uploads/2008/12/pic16f870-prob.rar прошика схема исходник
m.ix
Master Mixa
m.ix
Сообщение #2 От 04/07/2010 00:04 цитата
m.ix
Master Mixa
m.ix
Сообщение #3 От 04/07/2010 02:47 цитата
m.ix
Master Mixa
m.ix
Сообщение #4 От 04/07/2010 03:59 цитата
http://benryves.com/journal/3632205 на pic16F876A
http://heli.xbot.es/SuperProbe/SuperProbe.htm
http://heli.xbot.es/SuperProbe/SuperProbe3.png схема
http://ikon.wz.cz/mondo/sonda_2.php
http://ikon.wz.cz/mondo/files/super.obj прошивка переименовать в HEX
Prob
Логический тест
Этот режим очень полезен для обнаружения логических уровней или импульсы в цифровые схемы. На дисплее появится первая цифра 'H' на высоком уровне (около 3.7V), 'L' для низких (ниже питанием 0.8В) и "-" чтобы показать, что сигнал плавающей или высокий импеданс. Если импульсы выявлено более 0,5 микросекунд вторая цифра представляется 'P'.
PULS
Импульсный Генератор программного обеспечения
Формирует импульсы 500ns шириной в один из четырех частот, доступных, полезных для потребителей инъекционных сигналов в цифровые схемы. На дисплее отображается частота импульсов (5, 50, 500, 5,0) в течение последних трех цифр. Первая цифра показывает логический уровень обнаружены с примесью вниз (низкий) в середине (высокий импеданс или плавающие) и выше (высокий). При нажатии BUT1 порожденных поезда импульса 0,5 мкс до обнаружены противоположные уровне логики. С BUT2 кнопку, вы можете изменить частоты пульса между 4 разными: 5Hz, 50Hz, 500 Гц и 5 кГц. Частота пульса выбрали сохраняется в EEPROM, чтобы они не пропустить после его остановки.
VoLL
Низкий масштаб вольтметр
Простой вольтметр с разрешением около 5mV (хотя дисплей показывает только последние цифры кратны 10mV) со шкалой 0В до 5.00V, которая не должна быть превышена, поскольку это может привести к повреждению ПОС. Опорного напряжения самой власти (точность зависит от точности нормативной мощности). В новой версии программы 39 точное масштабирование происходит. До 1024 счетов раскол между двумя (один поворот вправо), для простоты, но он дал неточный результат: 5,12 В до 5,00 вход V Теперь масштабирование происходит в неподвижной точке V = (ANALOG1 * 500) / 1023 который обеспечивает точное значение.
VoLH
Вольтметр шкала высокой
Этот новый способ версия 39 равна VOLL однако сокращение 0В до 25.00V. Имейте в виду, что эта резолюция является примерно 25mV (1 кол-во), так как конвертер имеет только 1024 счетов. Это нормально, что последняя цифра на дисплее скачок 2 в обоих блоках. Для измерения совпадает с входным напряжением должны быть связаны между делителя напряжения 5 включает в себя серию резистора 1М 1% и параллельных 249K 1%.
diod
Прозвонка диодов
Показывает падение напряжения на стыке диоды, стабилитроны, или транзисторов. Это простое, 0-5V вольтметр, связанной с 10K резистор подключен к 5V, что делает небольшой источник питания. Измеренное значение имеет такой же точностью, как вольтметр, достаточной для выявления дефектных компонентов. После защиты стабилитрон Z1 параллельно с измерительной цепи максимальное значение, измеряемое в 4,5 V, напряжение, при котором начинает гнать стабилитроны D1.
Freq
Частотометр
Частота до 40MHz, время измерения 1 секунду. На дисплее появится цифра 4 тяжесть частота этого при входе. Нажатие BUT1 включен, чтобы показать как минимум 4 значащих цифр. Например, если на дисплее отображается '12 57 'на частоте 12,576 Гц. BUT1 нажав показывает, '2576 '- 4 цифры ниже. Исправлена десятичной точки указывает Khz, если мигает указывает МГц. Частота 42345678 Гц, как показано 42,34 с запятой мигать. Нажатие отображает BUT1 5678.
Cnt
Счетчик событий
Это простой счетчик импульсов. На дисплее отображается 4 наименее значащих цифр, при нажатии BUT1 4 цифры показали больший вес. BUT2 кнопки сбрасывает внимание к нулю.
Cap
Измерение ёмкости
Нажатие BUT1 мера емкости конденсатора соединены между зондом и массы. Диапазон измерения 001 до примерно 500 мкФ мкФ. Время измерения пропорциональна конденсатора для измерения 100 мкФ нужно несколько секунд.
Coil
Измерение индуктивности
Нажатие BUT1 меры индуктивность катушки соединены между зондом и массы. Диапазон измерения от 0,1 до 999,9 mH. Предполагается, что сопротивление катушки не более чем несколько Ом. Замыкание отзыв измерения массы калибровочных блока бесплатно.
SIG
Генератор сигналов
Генератор прямоугольных 500 Гц и 0,5 вольт, удерживая BUT1, очень полезно для тестирования аудио-и аналоговых схем.
ntSC
Генератор NTSC видео
Формирует изображение, сформированное структуры белые точки на черном фоне в видео формате NTSC для тестирования цепей с помощью этого формата изображения. В Испании мы используем стандарт PAL, я пытался его приемник Multistandard и работает хорошо, но мало пользы.
9600
9-битный (8N1) ASCII
Используется для проверки цифровых схем с использованием правильно получить серийный ввода данных. Каждый раз, когда вы нажимаете участок образуется BUT1 серии буквы А после возврата каретки и перевода строки (CR / LF есть). Сигнал полярности сторнируется таким образом, если измерять уровень высок сигнал генерируется нормальный (ноль стартовый бит). Если обратной полярности используется. BUT2 кнопку, чтобы изменить скорость: 1200, 2400, 4800, 9600, 19200, 34800, 57600 и 115200 бод.
Midi
MIDI генератор
Для проверки включения Музыкальные инструменты MIDI интерфейс. Отправить отметить, номер 60 (C в среднем) на любой из 16 каналов MIDI. Нажатие BUT1 послал заметка в ', чтобы освободить ее посылает' сведению выкл ". BUT2 кнопку, чтобы выбрать один из 16 каналов. Канал сохраняется от сбоев питания.
R/C.o
сервотестер
Позволяет проверить сервоприводы управления по радио. Генерирует импульсы 1 мс 2 мс возможность установить полный оборот сервомашинки. Дисплей показывает длительность импульса микросекунды. BUT1 кнопку уменьшается ширина импульса и BUT2 кнопку увеличивает его. По умолчанию это 1500 миллисекунд (1,5 мс в центре) каждый раз, когда вы выберите этот режим. Импульсы каждые 35 мс или около того (частота 28Hz).
R/C.i
сервотестер
Используется для тестового сигнала генераторов для управления по радио сервоприводы, RC ресивера или счетчик импульсов общий характер. На дисплее отображается микросекунд или миллисекунд входного сигнала остается на уровне (высокий или низкий, отобранные). Например, в 1500 составляет 1,5 мс (чтобы добраться до центра позиции для серво RC), если десятичная точка на дисплее данные показали представляют миллисекунд. При нажатии отображается BUT1 H и освобождения и непрерывно измеряет время, сигнал высокого уровня. Нажатие BUT2 показывает, L и выпуск непрерывно измеряет время сигнал низкого уровня. При отсутствии входного сигнала остается конечной мерой. При измерении можно увидеть небольшое мерцание на дисплее. В этом режиме проверяется 700US сигналов 100 мс, но может быть измерена с 10us более 16 секунд.
Генератор меандра
Генератор прямоугольных импульсов (50% рабочий цикл) от 1 до 9999 Гц BUT1 кнопку уменьшается частота и BUT2 кнопку увеличивает его. Это полезно для калибровки метров частоты сигналов в цифровые схемы придать т.д.
noiS
Генератор псевдослучайных сигналов
Цифровой шум (псевдо) на 10 кГц.
ir38
LED IR
Генератор прямоугольных импульсов 1 мс и 2,5 мс с на 38kHz. При подключении инфракрасного излучателя светодиодный может быть использован для тестирования модулей ИК-приемник.
PWM
Широтно-импульсной модуляции
Создает переменной ширины импульса от 3% до 97% примерно до 6kHz. Нажмите BUT1 импульса уменьшается, а увеличивает его BUT2 кнопку. Очень удобно использовать для тестирования усилителей для двигателей постоянного тока или PAP.
http://4shared.com/download/NPYIgP5p/SuperProbe.rar
m.ix
Master Mixa
m.ix
Сообщение #5 От 04/07/2010 05:46 цитата
m.ix
Master Mixa
m.ix
Сообщение #6 От 04/07/2010 09:01 цитата
Во время режима работы NTSC на экране монитора-телевизора выводятся белые точки - для центровки растра удобно.
m.ix
Master Mixa
m.ix
Сообщение #7 От 04/07/2010 17:35 цитата
измерил лит 4700
показал 5027
сравнил с иным дорогим прибором тоже 5 с чем то показал.
литы долго измеряет
4700 где то минуту полторы
10000 мкф минут эдак 5-10
ДОБАВЛЕНО 04/07/2010 19:01
Проверка диодов
Можно прозванивать диоды
проверять стабилитроны до 4.7-5.1 v
Ну и светодиоды.
m.ix
Master Mixa
m.ix
Сообщение #8 От 04/07/2010 18:36 цитата
минимальный на миллигенри предел
ДОБАВЛЕНО 04/07/2010 20:17
СОбственный генератор может выдавать прямоугольные 5в импульсы от 1Гц до 32кГц
GruVital
Не фанат форума
GruVital
Сообщение #9 От 04/07/2010 20:18 цитата
m.ix, Михаил, заинтересовал такой примочкой, обязательно соберу, будет время!
m.ix
Master Mixa
m.ix
Сообщение #10 От 04/07/2010 20:31 цитата
Если ещё у кого то есть авиамодели и серводвижки, то там тоже имеются сигналы для управления серводвижками.
Пока эту опцию не проверял.
В Режиме PROBe можно анализировать выходы логические
L
H
-P
LP
yucan
Сообщение #11 От 07/07/2010 07:42 цитата
Очень интересный прибор.Удивляюсь откуда у M.ixa столько времени на творчество?
генератором сервосигналов я так понял можно проверять сом порты
m.ix
Master Mixa
m.ix
Сообщение #12 От 07/07/2010 11:00 цитата
Наверное и можно проверять, правда ума не приложу как это и каким место проверять.
yucan
Сообщение #13 От 08/07/2010 09:03 цитата
Немного разобрался по генераторам этого пробника
В версии прошивки 41 19 функций
Генератором сервосигналов не знаю что можно проверять
А еще есть 9-битный последовательный выход 8+1 в формате ASCII это для
проверки сом портов. Формирует букву А + вк+пс скорость можно менять19,38,57 и 115 Кb
Генератор меандра от 1 до 9999 Гц
Генератор 38 кгц для проверки ик приемников
Генератор 500 гц 0,5 в
Генератор шума
m.ix
Master Mixa
m.ix
Сообщение #14 От 10/07/2010 14:44 цитата
Когда измерял ёмкость 10000мкф то на индикаторе высветилось 1156 к примеру и первая точка медленно при этом мигала где то в полГц
m.ix
Master Mixa
m.ix
Сообщение #15 От 22/08/2010 04:16 цитата
попробовал измерить 18000мкф
измерил
но времени на это ушло где то минут пять
1000мкф 30секунд
100мкф 3-4скунды
yucan
Сообщение #16 От 28/08/2010 10:02 цитата
Собрал но ни фига не разберусь.
вроде работает но где какая функция?
При включении 3 черты - так должно быть?
m.ix
Master Mixa
m.ix
Сообщение #17 От 28/08/2010 13:40 цитата
при включении высвечивается на секунду
Prob
а после лишь одна черта.
переключение функций идёт двумя кнопками одна при этом постоянно нажата
останавливаясь на нужной опускаем обе.
Zeba
Zeba
Сообщение #18 От 19/09/2010 19:25 цитата
А хекс имеется к первому вареанту на pic16f870 ? Странный файл прошивки там
m.ix
Master Mixa
m.ix
Сообщение #19 От 19/09/2010 20:44 цитата
Zeba, я им прошил
что ты и видишь на скринах.
Zeba
Zeba
Сообщение #20 От 19/09/2010 22:39 цитата
m.ix, попробую собрать, клёвая штука классно! А в каких приделах можно ёмкость мерять? В описании 500 мкФ, а например 10000 мкФ и большая погрешность будет?
