Монитор hitachi CM615-ET откушена фишка,помогите распаять
  Список форумов » CRT-мониторы
Хищник
Хищник
Сообщение #1 От 24/02/2010 21:12 цитата
Монитор hitachi CM615-ET , откушен разъём , провода по цвету распаять на новую фишку , кто поможет , буду очень благодарен.
ирекан
Сообщение #2 От 24/02/2010 22:03 цитата
Nearly all modern PC graphics cards use the same 15 pin VGA connector that the original IBM VGA card used. VGA=Video Graphics adapter or Video Graphics Array.
There are at least four versions of the VGA connector, which are the three-row 15 pin DE-15 (also called mini sub D15) in original and DDC2 pinouts, a less featureful and far less common 9-pin VGA, and a Mini-VGA used for laptops. The image and below table are the newer 15-pin VGA VESA DDC2 connector pinout.
VGA connector pinout:
Pin Name Dir Description
1 RED Red Video (75 ohm, 0.7 V p-p)
2 GREEN Green Video (75 ohm, 0.7 V p-p)
3 BLUE Blue Video (75 ohm, 0.7 V p-p)
4 ID2 Monitor ID Bit 2
5 GND Ground
6 RGND Red Ground
7 GGND Green Ground
8 BGND Blue Ground
9 KEY - Key (No pin)
10 SGND Sync Ground
11 ID0 Monitor ID Bit 0
12 ID1 or SDA Monitor ID Bit 1
13 HSYNC or CSYNC Horizontal Sync (or Composite Sync)
14 VSYNC Vertical Sync
15 ID3 or SCL Monitor ID Bit 3
Note: Direction is Computer relative Monitor. All VGA pinout signals except R, G, B are TTL level signals.
VGA pinout : monitor ID detection pin assignments
4 11 12
ID2 ID0 ID1
n/c n/c n/c no monitor
n/c n/c GND Mono monitor which does not support 1024x768
n/c GND n/c Color monitor which does not support 1024x768
GND GND n/c Color monitor which supports 1024x768
GND means connected to ground
n/c means that the pin is not connected anywhere
This monitor type detection is becoming more and more obsolete nowadays. New VGA plug-and-play monitors communicate with the computer according to VESA DDC standard.
VGA VESA DDC
VESA Display Data Channel is a method for integrating digital interface to VGA connector so as to enable the monitor and graphics card to communicate. There are two different levels of DDC: DDC1 and DDC2.
VGA DDC1
DDC1 allows the monitor to tell its parameters to the computer. The following VGA card connector pins have to be changed to allow DDC1 functions:
VGA pin new function
9 Optional +5V output from graphics card
12 Data from display
14 Standard vertical sync signal which works also as data clock
15 Monitor ID3
When the VGA graphics card detects data on data-line it starts to read the data coming from the monitor synchronous to vertical sync pulse. Vertical sync pulse frequency can be increased up to 25 KHz for the time of the data transfer if a DDC1 compliant monitor is found (be sure not to send those high frequencies to non DDC1 monitors!).
VGA DDC2
DDC2 allows bidirectional communication: monitor can tell its parameters and the computer can adjust monitor settings. The bidirectional data bus is a synchronous data bus similar to Access Bus and is based on I2C technology. The following pins on VGA pinout have to be changed to enable DDC2 to work:
12 Bidirectional data line (SDA)
15 Data clock (SCL)
The signals in the data bus are standard I2C signals. The computer provides 15 kohm pullup for the SDA and SLC lines. Monitor must provide 47 kohm pull-up on SCLK line.
ДОБАВЛЕНО 24/02/2010 23:06
15 ног, кабель с одной стороны встроен в корпус(заведомо должен быть цел), с другой идет на видеокарту разъем станд.VGA, если кабель нигде не поврежден, то вот распиновка на разъем: 1нога -розовый(красный), 2 -серый, 3 -голубой(синий), 4 -масса, 5 -масса, 6-масса, 7-масса, 8-масса, 9-коричневый, 10 - черный, 11-масса, 12-оранж, 13 -желтый, 14-зеленый, 15-белый. Распределил по цветам,так проще=)
TE
Сообщение #3 От 24/02/2010 22:42 цитата
Хищник, ждать, что кто-то выложит соединение по цветам проводов, бесполезно, схемы на него тоже нет, а вскрыв монитор, с помощью глаз и тестера всегда можно разобраться.
georgi d
georgi d
Сообщение #4 От 25/02/2010 14:21 цитата
TE писал:
TE, я здесь кое что нашел.
http://archive.espec.ws/section45/file19551.html
Хищник
Хищник
Сообщение #5 От 28/02/2010 23:42 цитата
Спасибо всем огромное за помощь , всё работает , монитор великолепный , хоть и 2001 го года выпуска.
