My play style is the most boring one and all my friends crit
  Список форумов » TFT-мониторы
CarlosBrathwaite
Сообщение #1 от 30/12/2021 17:38 цитата
Greetings! people need help, the machine stood for several years as not working, it was decided to restore it, the machine did not show any signs of life, later it turned out that the tracks on the module were rotted, threw the jumpers and the display started working, but knocked out the error F09 went into the settings, dropped it to the factory ones, checked it there the functionality of all pumps and valves, after which the F09 error went away, everything seems to be fumbling, the display normally switches to the choice of the washing program mode, but at the transition stage, the robots of the initial process, the machine knocks out the next error F01, as I understand it, is this connected with water heating? who will have what thoughts? the washing process can be continued by pressing START,https://19216811.cam/ https://1921681001.id/
SASHATOD
SASHATOD
Сообщение #2 от 30/12/2021 18:29 цитата
CarlosBrathwaite, As far as I know, there are no washing machines in monitors.
Antiox
Сообщение #3 от 03/01/2022 17:51 цитата
Definitely! улыбка
