сомнения от величины резистора R223 Монитор LG L173SA источн
  Список форумов » TFT-мониторы
eletmoraes
Сообщение #1 от 18/06/2014 22:29 цитата
Monitor did not care before. Another technician placed a R223 resistor value 0.1 ohms and diode ZD260 S24 (?). I did some research and found that the correct diode is P6KE10A.
Board source code is: FSP045-2PI01
C251, C252 , C253 , C319 have been replaced.
put the 10k resistor value and the diode P6KE10A, to turn the monitor lit the led on the power for only a moment to clear soon then repair the diode heats P6KE10A much.
Сообщение #2 от 18/06/2014 22:43 цитата
вас ист дас?!
