Akira CT-14SX9R шасси 3Y11
B.B.
Мастер
B.B.
Сообщение #1 От 16/07/2008 16:46 цитата
Akira CT-14SX9R шасси 3Y11 / Akira CT-14NX9R, 14PZS1/CN, 21PZS1/CN, CT-14NK9A, CT-14NX9A, CT-14SD9A, CT-14SD9CP, CT-14SD9R, CT-14SJ9A, CT-14SJ9CP, CT-14SJ9R, CT-14SK9A, CT-14SK9CP, CT-14SK9R, CT-14SR9R, CT-21LS9A, CT-21NK9A, CT-21NL9CP, CT-21NS9CP, CT-21NX9A, CT-21NX9R, CT-21PC9CP(SKD), CT-21PC9R, CT-21PQ9CP(SKD), CT-21PQ9R, CT-21PX9R, CT-21SC9A, CT-21SC9R, CT-21SD9R, CT-21SJ9A, CT-21SJ9CP, CT-21SJ9R, CT-21SK9A, CT-21SK9R, CT-21SQ9A, CT-21SQ9R, CT-21ST9CP, CT-21TF9A, CT-21TF9R, CT-21TR9CP, CT-21WG9P
Клоны: ERC 21NI60 / Erisson 1406, 1407, 1465, 2106, 2108, 2109, 2120, 21F1, 21F7, 21NI60, 21TI70, 3707, 5407, 5409, 5408F, S14 / Hyundai H-TV1401, H-TV2100PF, H-TV2101 / Skyworth 21N1 / Supra CTV-14NI, CTV-21NX / Techno TS-3707, TS-5407, TS-5408F, TS-5409
СХЕМА шасси 3Y11 (0.33 MB)
ПРОШИВКА на шасси 3Y11
ВХОД В СЕРВИСНОЕ МЕНЮ
СОСТАВ ШАССИ:
Micom - LC863328C 55W0
Memory - 24C08W
SMPS - STR-G6653 & TLP621
TR Chopper - BCK-35-LF01X
SAW - Q2955M
Secam - даташит на LA7642N
Video - даташит на LA76810A
Vertical - LA7840
Sound - даташит на LA4285
Tuner - EWT5W3S32-E08W
Tube - A34AGT13X63
FBT - BSC23-N0114 (HR8915)
HOT - 2SD2499
RGB Amp. - 2SC4544
Пульт: - PC1202-01
IC remote - SC73C1202-005
B.B.
Мастер
B.B.
Сообщение #2 От 23/07/2008 06:37 цитата
Akira CT-14N19A шасси 3Y11 / Akira CT-14HS9A(B), CT-14HS9A(G), CT-14HS9A(S), CT-14HS9CP(S), CT-14HS9N(G), CT-14HS9R(B), CT-14M9A, CT-14M9CP, CT-14M9CPT, CT-14M9N, CT-14M9P, CT-14M9R, CT-14NI9A, CT-14NI9CP, CT-14NI9N, CT-14NK9A, CT-14NK9CP, CT-14NS9N, CT-14NX9A, CT-14NX9CP, CT-14NX9N, CT-14NX9P, CT-14SK9R, CT-21DS9A, CT-21DS9CP, CT-21DS9CP(IKD), CT-21DS9CP(SKD), CT-21DS9N, CT-21DS9R, CT-21FS9A, CT-21FS9C, CT-21FS9CPT, CT-21FS9MK1A, CT-21FS9MK1AE, CT-21FS9MK1AT, CT-21FS9MK1CP, CT-21LS9A, CT-21LS9A(IKD), CT-21LS9C, CT-21LS9CP, CT-21LS9CPT(B), CT-21LS9CPT(S), CT-21LS9N, CT-21LS9R, CT-21NI9A, CT-21NI9A(IKD), CT-21NI9CP, CT-21NI9N, CT-21NK9A, CT-21NK9CP, CT-21NK9N, CT-21NS9A, CT-21NS9N, CT-21NX9A, CT-21NX9CP, CT-21NX9N, CT-21NX9R, CT-21PF9A
Клоны: Akai CTG-2120
СХЕМА шасси 3Y11 (0.38 MB)
СОСТАВ ШАССИ:
Micom - LC863324A 5S68
Memory - 24C04
SMPS - STR-G6653
TR Chopper - BCK-35-087B
Vertical - LA7840
Tuner - XG 6VD 96A
FBT - JF0501-1901 (HR8915)
HOT - 2SD2499
Пульт: - FHS08A-00
IC Remote - µ61340-20
ТЕМЫ С НЕИСПРАВНОСТЯМИ:
Прыгают выходные напряжения
Мал размер и чёрно-белое изображение
Нет SECAM
Не запускается БП
Не включается, блок питания работает
Не включается из дежурного режима
Некачественное с зеленью изображение
Только красный цвет
Малая яркость изображения
H
