Philips 25ST1724 шасси GR2.2 | |
| goga_tv 21/04/2010 01:02 |
Philips 25ST1724 шасси GR2.2 / Philips 213372SB, 213842SB, 213862SB, 213962SB, 213982SB, 21GR2131, 21GR2937, 21PT440A, 21PT442A, 21PT520A, 21PT522A, 21PT530A, 21PT532A, 21PT570A, 21ST2430, 21ST2436, 21ST2630, 21ST2636, 21ST2637, 21ST2730, 21ST2731, 21ST2737, 21ST2931, 21ST2937, 255251CB, 255741CB, 255831CB, 255942SB, 255962SB, 256372SB, 256392SB, 256862SB, 25GR9763/33, 25MN1350, 25MN1353, 25MN1355, 25MN1356, 25MN1550, 25MN1553, 25PT400A, 25PT400A, 25PT405A, 25PT410A, 25PT430A, 25PT440A, 25PT442A, 25PT450A, 25PT451A, 25PT452A, 25PT470A, 25PT470B, 25PT472A, 25PT480A, 25PT480B, 25PT480C, 25PT481B, 25PT482A, 25PT490A, 25PT492A, 25PT510A, 25PT510B, 25PT512A, 25PT512B, 25PT520A, 25PT521B, 25PT522A, 25PT530A, 25PT532A, 25PT540A, 25PT542A, 25PT570A, 25PT570B, 25ST2161, 25ST2167, 25ST2451, 25ST2454, 25ST2457, 25ST2657, 25ST2664, 25ST2666, 25ST2751, 25ST2759, 25ST2760, 25ST2761, 25ST2767, 25ST2769, 25ST2860, 25ST2864, 25ST2961, 25ST2967, 287231CB, 287342SB, 287942SB, 287962SB, 288372SB, 288392SB, 288572SB, 288572SB/02B, 288862SB, 28MN1370, 28MN1376, 28MN1570, 28PT400A, 28PT400A/42, 28PT405A, 28PT410A, 28PT440A, 28PT442A, 28PT450/42, 28PT450A, 28PT450A/00, 28PT450A/42, 28PT451A, 28PT452A, 28PT470A, 28PT470B, 28PT472A, 28PT480A, 28PT480B, 28PT480C, 28PT481B, 28PT482A, 28PT490A, 28PT492A, 28PT510A, 28PT510B, 28PT512A, 28PT512B, 28PT520A, 28PT522A, 28PT530A, 28PT530A/00, 28PT532A, 28PT540A, 28PT542A, 28PT570A, 28PT570B, 28ST2181, 28ST2181/10B, 28ST2181/19B, 28ST2187, 28ST2281, 28ST2281/10B, 28ST2281/16B, 28ST2287, 28ST2287/19B, 28ST2471, 28ST2471/02B, 28ST2471/08B, 28ST2471/10B, 28ST2471/12B, 28ST2471/13B, 28ST2471/16B, 28ST2477, 28ST2477/10B, 28ST2477/42B, 28ST2485, 28ST2674/19B, 28ST2686/19B, 28ST2686/39B, 28ST2687/19B, 28ST2687/42B, 28ST2761, 28ST2771, 28ST2780/08B, 28ST2780/10B, 28ST2780/13B, 28ST2780/16B, 28ST2781/02B, 28ST2781/05B, 28ST2781/08B, 28ST2781/10B, 28ST2781/13B, 28ST2781/16B, 28ST2781/22B, 28ST2784/13B, 28ST2785, 28ST2786/10B, 28ST2787/10B, 28ST2787/42B, 28ST2789/02Z, 28ST2789/10Z, 28ST2880/12B, 28ST2884/12B, 28ST2981/10B, 28ST2981/16B, 28ST2987/19B, 52NA2304, 52NA2307, 52NA2317, 52NA2364, 52NA2366, 52NA2376, 52NA2377, 52TA4310, 52TA5210, 52TA5211, 52TB4290, 52TB5190, 52TB5191, 62CA1563, 63CA1503, 63CA1505, 63CA1513, 63CA1515, 63CA1563, 63CA1573, 63CA1595, 63NA2514, 63NA2517, 63NA2574, 63NA2576, 63NA2607, 63NA2617, 63NA2618, 63NA2666, 63NA2676, 63NA2677, 63TA3910, 63TA3960, 63TA4010, 63TA4110, 63TA4310, 63TA4410, 63TA4411, 63TA4610, 63TA4611, 63TA5210, 63TA5211, 63TB3890, 63TB4390, 63TB4391, 63TB4590, 63TB4591, 63TB5190, 63TB5191, 70CA1703, 70CA1705, 70CA1763, 70NA2714, 70NA2717, 70NA2774, 70NA2776, 70NA2807, 70NA2808, 70NA2817, 70NA2818, 70NA2819, 70NA2866, 70NA2876, 70NA2877, 70NA2879, 70TA3910, 70TA3960, 70TA4010, 70TA4310, 70TA4410, 70TA4411, 70TA4610, 70TA4611, 70TA5210, 70TA5211, 70TB3890, 70TB4390, 70TB4391, 70TB4590, 70TB4591, 70TB5190, 70TB5191, M7229
МАНУАЛ шасси GR2.2 (12MB) СХЕМА шасси GR2.2 (1,88MB)
ПРОШИВКА на шасси GR2.2 ВХОД В СЕРВИСНОЕ МЕНЮ СОСТАВ ШАССИ: Micom - TMP47C1637N U216 Memory - SMPS - CNR50, TDA8385, BUT12AF TR Chopper - SAW - Delay - даташит на TDA4661 Color - TDA4680, TDA4565, даташит на TDA4510, (TDA4650) VIF - TDA8417 Vertical - Discret Horizontal/Vertical sync - даташит на TDA2579B Teletext - SAA5246A Sound - SIF - даташит на TDA3857 Stereo - даташит на TDA8425 Tuner - UV916 Tube - A66EAK51X03 FBT - 37992 (HR6485) HOT - BU508A RGB Amp. - Discret Пульт: - IC remote - ТЕМЫ С НЕИСПРАВНОСТЯМИ: Сгорает HOT Выгорает цепь protect Включение DK Плохо стартует Плывет изображение по краям Садит питание 148V после вкл. Нарушения цветопередачив Мигает светодиод Обратный ход по кадру Проблемы со строчной Сгорает транзистор E/W Самопризвольное переключение каналов Поиски прошивки Установить СЕКАМ Настройка каналов Проблемы с геометрией или МП Установить СЕКАМ Блок питания Поиски прошивки Не работает радиоканал Нелинейное изо по горизонту Дефект изображения Заворот по кадру сверху Нет настройки каналов Ошибка "ERR SAT" Не выходит из сервиса |
