Philips 289279IR/22M шасси G110
киев
30/10/2013 16:27
Philips 289279IR/22M шасси G110 / Philips 21GR1990 (G110-S), 21GR5656, 21GR5750, 21GR5856, 21GR6655 (G110-S), 21GR6755 (G110-S), 21GR6756, 21GR6761 (G110-S), 21GR6763, 250175IR, 25G6265IR, 25GR6269IR (G110 SVHS), 256275IR, 256279IR, 256289IR, 256665IR, 256769IR, 256289IR, 256665IR, 256769IR, 256775IR, 256865IR, 258279IR (G110 SVHS), 25GR1990 (G110-S), 25GR5560, 25GR5616 (G110-2), 25GR5660, 25GR5664, 25GR5666, 25GR5667, 25GR5668, 25GR57, 25GR5711 (G110-2), 25GR5716 (G110-2), 25GR5721 (G110-2), 25GR5760, 25GR5762, 25GR5763, 25GR5764 (G110-NIC), 25GR5765, 25GR5768, 25GR5775, 25GR5868 (G110 SVHS), 25GR5964 (G110 SVHS), 25GR6765 (G110-S), 25GR6766 (G110-S), 25GR6771, 25GR9660, 25GR9666, 25GR9667, 25GR9760 (G110 SVHS), 25GR9761, 25GR9762, 25GR9763, 25GR9765, 25GR9768, 25GR9867, 25GR9960, 25GR9963, 25GR9968, 25GR9975/22B (G110 SVHS), 280175IR (G110-S), 287229IR, 287265IR, 287269IR, 287275IR, 287279IR, 287289IR, 28765IR, 287665IR, 287775IR, 28777SIR (ch.G110 NICAM), 287865IR, 287869IR, 289279IR, 28GE9970, 28GR1990 (G110-S), 28GR5606 (G110-2), 28GR5631, 28GR5636 (G110-2), 28GR5670, 28GR5674, 28GR5676, 28GR5677, 28GR5678, 28GR5701 (G110-2), 28GR5706 (G110-2), 28GR5701 (G110-2), 28GR5731 (G110-2), 28GR5736 (G110-2), 28GR5765, 28GR5770, 28GR5772, 28GR5773, 28GR5774, 28GR5775, 28GR5776, 28GR5777, 28GR5779, 28GR5878, 28GR5974, 28GR6775 (G110-S), 28GR6776, 28GR6780, 28GR9670, 28GR9676, 28GR9677, 28GR9770/30B, 28GR9772, 28GR9773, 28GR9775, 28GR9776, 28GR9777, 28GR9778, 28GR9779, 28GR9875, 28GR9877, 28GR9970, 28GR9973, 28GR9977, 28GR9979, 414488IR (G110-PTV), 41GR8840, 41GR8841, 41KV8408 (G110-PTV), 41KV8428 (G110-PTV), 41KV8438 (G110-PTV), 46GR8850 (G110-PTV), 46GR8451 (G110-PTV), 46KV8508 (G110-PTV), 46KV8528 (G110-PTV), 46KV8538 (G110-PTV), 52KV5717, 63KB5626, 63KV5176 (G110-2), 63KV5616, 63KV5617, 63KV5626, 63KV5637, 63KV5686, 63KV5687, 63KV5697, 63KV9616, 63KV9617, 63KV9636, 63KV9637, 63KV9647, 63KV9656, 63KV9686, 63KV9687, 63KV9817, 70KV5027 (G110-2), 70KV5076 (G110-2), 70KV5317 (G110-2), 70KV5687, 70KV5716, 70KV5717, 70KV5726, 70KV5737, 70KV5787, 70KV9656, 70KV9716, 70KV9717, 70KV9736, 70KV9737, 70KV9747, 70KV9787, 70KV9917
МАНУАЛ шасси G110 (4.73 MB)
СХЕМА шасси G110 (1.68 MB)
СХЕМА шасси G110 (1.19 MB)
ПРОШИВКА на шасси G110
СОСТАВ ШАССИ:
Micom - TMP47C634N
Memory - X2402P or даташит на PCD8582
SMPS - 2SC3793B or BUT18AF
TR Chopper -
SAW - OFWG3203
Secam - TDA8490
Delay - TDA8451, TDA8452
Video - TDA8390
IF - даташит на TDA2549
Vertical - 2SD1266 & BD234
Teletext - SAA5243P/E, PCF84C81P/074, FCB61C65-70P, SAA5231
Sound - TDA1521
Stereo - TDA8405
Tuner - UV816
TV/AV - HEF4053BP
Tube - A66EAK22X13
FBT - 38161 (HR6484) аналог 37554 (HR6213)
HOT - BU508AF
RGB Amp. - TEA5101
Пульт: - RP420 (RC7500 - RC7507)
IC remote -
Other ICs - TDA2579A
ON/OFF -
ТЕМЫ С НЕИСПРАВНОСТЯМИ:
Блок питания
Блок питания
Блок питания
Блок питания
Кадровая
Коротит строчная
Вопрос по процу
Не запускается БП
Не запускается БП
Не запускается БП
Графика
Транзисторы регулировки фазы
Периодически сгорает ключевой транзистор в питании
ТДКС
Исчезает стерео
Ошибка F4
Опознать и задефектовать строчник
Сгорает транзистор в БП
Проблема с памятью
Нет реакции на пульт и кнопки
Не работает БП в дежурке
Произвольно выкл. и скачет звук
Сгорает HOT
Поиски прошивки
Поиски схемы
