Philips 25ST1724 шасси GR2.2
goga_tv
goga_tv
Сообщение #1 От 21/04/2010 01:02 цитата
Philips 25ST1724 шасси GR2.2 / Philips 213372SB, 213842SB, 213862SB, 213962SB, 213982SB, 21GR2131, 21GR2937, 21PT440A, 21PT442A, 21PT520A, 21PT522A, 21PT530A, 21PT532A, 21PT570A, 21ST2430, 21ST2436, 21ST2630, 21ST2636, 21ST2637, 21ST2730, 21ST2731, 21ST2737, 21ST2931, 21ST2937, 255251CB, 255741CB, 255831CB, 255942SB, 255962SB, 256372SB, 256392SB, 256862SB, 25GR9763/33, 25MN1350, 25MN1353, 25MN1355, 25MN1356, 25MN1550, 25MN1553, 25PT400A, 25PT400A, 25PT405A, 25PT410A, 25PT430A, 25PT440A, 25PT442A, 25PT450A, 25PT451A, 25PT452A, 25PT470A, 25PT470B, 25PT472A, 25PT480A, 25PT480B, 25PT480C, 25PT481B, 25PT482A, 25PT490A, 25PT492A, 25PT510A, 25PT510B, 25PT512A, 25PT512B, 25PT520A, 25PT521B, 25PT522A, 25PT530A, 25PT532A, 25PT540A, 25PT542A, 25PT570A, 25PT570B, 25ST2161, 25ST2167, 25ST2451, 25ST2454, 25ST2457, 25ST2657, 25ST2664, 25ST2666, 25ST2751, 25ST2759, 25ST2760, 25ST2761, 25ST2767, 25ST2769, 25ST2860, 25ST2864, 25ST2961, 25ST2967, 287231CB, 287342SB, 287942SB, 287962SB, 288372SB, 288392SB, 288572SB, 288572SB/02B, 288862SB, 28MN1370, 28MN1376, 28MN1570, 28PT400A, 28PT400A/42, 28PT405A, 28PT410A, 28PT440A, 28PT442A, 28PT450/42, 28PT450A, 28PT450A/00, 28PT450A/42, 28PT451A, 28PT452A, 28PT470A, 28PT470B, 28PT472A, 28PT480A, 28PT480B, 28PT480C, 28PT481B, 28PT482A, 28PT490A, 28PT492A, 28PT510A, 28PT510B, 28PT512A, 28PT512B, 28PT520A, 28PT522A, 28PT530A, 28PT530A/00, 28PT532A, 28PT540A, 28PT542A, 28PT570A, 28PT570B, 28ST2181, 28ST2181/10B, 28ST2181/19B, 28ST2187, 28ST2281, 28ST2281/10B, 28ST2281/16B, 28ST2287, 28ST2287/19B, 28ST2471, 28ST2471/02B, 28ST2471/08B, 28ST2471/10B, 28ST2471/12B, 28ST2471/13B, 28ST2471/16B, 28ST2477, 28ST2477/10B, 28ST2477/42B, 28ST2485, 28ST2674/19B, 28ST2686/19B, 28ST2686/39B, 28ST2687/19B, 28ST2687/42B, 28ST2761, 28ST2771, 28ST2780/08B, 28ST2780/10B, 28ST2780/13B, 28ST2780/16B, 28ST2781/02B, 28ST2781/05B, 28ST2781/08B, 28ST2781/10B, 28ST2781/13B, 28ST2781/16B, 28ST2781/22B, 28ST2784/13B, 28ST2785, 28ST2786/10B, 28ST2787/10B, 28ST2787/42B, 28ST2789/02Z, 28ST2789/10Z, 28ST2880/12B, 28ST2884/12B, 28ST2981/10B, 28ST2981/16B, 28ST2987/19B, 52NA2304, 52NA2307, 52NA2317, 52NA2364, 52NA2366, 52NA2376, 52NA2377, 52TA4310, 52TA5210, 52TA5211, 52TB4290, 52TB5190, 52TB5191, 62CA1563, 63CA1503, 63CA1505, 63CA1513, 63CA1515, 63CA1563, 63CA1573, 63CA1595, 63NA2514, 63NA2517, 63NA2574, 63NA2576, 63NA2607, 63NA2617, 63NA2618, 63NA2666, 63NA2676, 63NA2677, 63TA3910, 63TA3960, 63TA4010, 63TA4110, 63TA4310, 63TA4410, 63TA4411, 63TA4610, 63TA4611, 63TA5210, 63TA5211, 63TB3890, 63TB4390, 63TB4391, 63TB4590, 63TB4591, 63TB5190, 63TB5191, 70CA1703, 70CA1705, 70CA1763, 70NA2714, 70NA2717, 70NA2774, 70NA2776, 70NA2807, 70NA2808, 70NA2817, 70NA2818, 70NA2819, 70NA2866, 70NA2876, 70NA2877, 70NA2879, 70TA3910, 70TA3960, 70TA4010, 70TA4310, 70TA4410, 70TA4411, 70TA4610, 70TA4611, 70TA5210, 70TA5211, 70TB3890, 70TB4390, 70TB4391, 70TB4590, 70TB4591, 70TB5190, 70TB5191, M7229
МАНУАЛ шасси GR2.2 (12MB)
СХЕМА шасси GR2.2 (1,88MB) классно!
ПРОШИВКА на шасси GR2.2
ВХОД В СЕРВИСНОЕ МЕНЮ
СОСТАВ ШАССИ:
Micom - TMP47C1637N U216
Memory -
SMPS - CNR50, TDA8385, BUT12AF
TR Chopper -
SAW -
Delay - даташит на TDA4661
Color - TDA4680, TDA4565, даташит на TDA4510, (TDA4650)
VIF - TDA8417
Vertical - Discret
Horizontal/Vertical sync - даташит на TDA2579B
Teletext - SAA5246A
Sound -
SIF - даташит на TDA3857
Stereo - даташит на TDA8425
Tuner - UV916
Tube - A66EAK51X03
FBT - 37992 (HR6485)
HOT - BU508A
RGB Amp. - Discret
Пульт: -
IC remote -
ТЕМЫ С НЕИСПРАВНОСТЯМИ:
Сгорает HOT
Выгорает цепь protect
Включение DK
Плохо стартует
Плывет изображение по краям
Садит питание 148V после вкл.
Нарушения цветопередачив
Мигает светодиод
Обратный ход по кадру
Проблемы со строчной
Сгорает транзистор E/W
Самопризвольное переключение каналов
Поиски прошивки
Установить СЕКАМ
Настройка каналов
Проблемы с геометрией или МП
Установить СЕКАМ
Блок питания
Поиски прошивки
Не работает радиоканал
Нелинейное изо по горизонту
Дефект изображения
Заворот по кадру сверху
Нет настройки каналов
Ошибка "ERR SAT"
Не выходит из сервиса
U
