LG CF-21K51KE / RT-20CA70M шасси MC-019A
B.B.
Мастер
B.B.
Сообщение #1 От 20/07/2008 18:50 цитата
LG CF-21K51KE шасси MC-019A / LG CF-20D31KE, CT-21Q66KEX, RT-14CA51M, RT-20CC50E, RT-21FB20RQ, RT-21FB50RQ, RT-21FB90RQ
СХЕМА шасси MC-019A (1.09 MB)
ПРОШИВКА на TV LG CF-21K51KE
ВХОД В СЕРВИСНОЕ МЕНЮ
СОСТАВ ШАССИ:
Size - 318x245mm
UOC - TDA9381PS/N2/ UOSFMOSD (V1.38) / TDA9381PS/N3/3/1726
Memory - AT24C16
SMPS - даташит на STR-F6654R
TR Chopper - 151-A13P
SAW - K2971M
Vertical - LA7840
Sound - даташит на TDA7297
Stereo - даташит на TDA9859
Tuner - 6700VPF009B
Tube - A51QAE320X + FT2134D
FBT - 6174V-6002K (BSC23-N0101)
HOT - 2SD5702
RGB Amp. - TDA6107JF
Пульт: - 6710V00070B
IC remote - 3C1840DF7SKB1 LG8989-01A
RCCreator - 023280588C2AD6AD612
Yuritsh
Yuritsh
Сообщение #2 От 30/01/2012 19:37 цитата
LG RT-20CA70M шасси MC-019A / LG 21FE3RGE-TY, CE-20F60K, CE-20T20K, CE-21F60KX, CE-21M64K, CE-21M66KX, CE-21T22KX, CF-14F60K, CF-14F80K, CF-14F90K, CF-14i30K, CF-14i30KEX, CF-14i30KX, CF-14J50K, CF-14K40KE, CF-14K41KE, CF-14S13KE, CF-14T30K, CF-16K40KE, CF-16K41KE, CF-20F30K, CF-20F60K, CF-20F80K, CF-20i30K, CF-20i30KEX, CF-20i30KX, CF-20J50K, CF-20K40KE, CF-20K41KE, CF-20K51KE, CF-20K53KE, CF-20S11KE, CF-20S13KE, CF-20S31KE, CF-20S41KE, CF-20S43KE, CF-20T30K, CF-20T31KS, CF-20T60, CF-2130KE, CF-21CA810EX, CF-21D31KE, CF-21F30K, CF-21F80K, CF-21i30K, CF-21i30KEX, CF-21i30KX, CF-21K40KE, CF-21K41KE, CF-21K53KE, CF-21Q42KEX, CF-21S11KE, CF-21S13KE, CF-21S31KE, CF-21S41KE, CF-21S43KE, CF-21T20K, CF-21T300EX, CF-21T30K, CN-20T20K, CT-14K40KE, CT-14K41KE, CT-15Q91KE, CT-16K40KE, CT-16K41KE, CT-20D31KE, CT-20F60K, CT-20K40KE, CT-20K41KE, CT-21F60K, CT-21K40KE, CT-21K41KE, CT-21Q21KE, CT-21Q41KE, CT-21Q42KEX, CT-21Q65KE, CT-21Q65KEX, CT-21Q92KEX, CT-21T30KE, RE-20CB10MX, RE-21FB30RX, RE-21FD10RX, RF-14CA80M, RF-14CA80MX, RF-14CC20MX, RF-20CA80VE, RF-20CA80VM, RF-20CA80VQ, RF-20CC20M, RF-20CC20V, RF-21CA80M, RF-21CA80MX, RF-21CA80VE, RF-21CA80VM, RF-21CA80VQ, RF-21CB90VQ, RF-21CC20M, RF-21CC20V, RF-21FB30VX, RT-14CA52M, RT-14CA80M, RT-14CA80MX, RT-14CC20M, RT-17FB70V, RT-20CA50M, RT-20CA60M, RT-20CA80VE, RT-20CA80VM, RT-20CA80VQ, RT-20CB10M, RT-20CC20M, RT-20CC20V, RT-20CC20VX, RT-21CA50M, RT-21CA70M, RT-21CA80M, RT-21CA80MX, RT-21CA80VE, RT-21CA80VM, RT-21CA80VQ, RT-21CC20M, RT-21CC20V, RT-21CC20VX, RT-21FA32X, RT-21FB20VW, RT-21FB30M, RT-21FB30MX, RT-21FB30V, RT-21FB30VX, RT-21FB50V, RT-21FB50VE, RT-21FB700VX, RT-21FB70RN, RT-21FB70RQ, RT-21FB70RX, RT-21FB70V, RT-21FB70VX, RT-21FC40RQ
ПРОШИВКА на TV LG RT-20CA70M
СОСТАВ ШАССИ:
Size - 318x245mm
UOC - TDA9381PS/N2/3i0792 OICTMPH010A / TDA9361PS/N2/5I (VER1.52)
Memory - AT24C16A
TR Chopper - 6170VMCB01L
SAW - K7252M
Vertical - LA7840
Sound - даташит на TDA2006
Tuner - 6700VPF016B / 6700VPF009Z TAEM-G001D / 6700MF0001E TAFD-Z242D
TV/AV - даташит на LA7016
Tube - A48JLL90X07 / A51QDX992X(H)
FBT - 6174V-6002K BSC23-N0101 / 6174V-6006E BSC23-N0107 (HR80033)
HOT - даташит на TT2140
Пульт: - 6710V00090A / 6710V00090D
ТЕМЫ С НЕИСПРАВНОСТЯМИ:
Замкнула отклоняющая ОТКЛОНЯЮЩАЯ СИСТЕМА
Нет синхронизации
Изображение мигает как стробоскоп
Нет изображения и звука
Пропала синхронизация
Не работает AV Не работает AV-вход
Cлетела прошивка
Потерялись пункты меню
Сгорает HOT
Hа экране ЛОХ
Нет цветности в СЕКАМ
Как перевести в дежурный режим
Полетел строчник: 6174V-6006E
Засветка белым с ЛОХ
Очень слабая контрастность
Мигает изображение
Заужен растр по вертикали
Нет фокуса
Слабый приём
Нет настройки на каналы
Срабатывает защита БП
Отсутствует звук в режиме TV
F
